Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 KMP  P38 Engine offset? >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 11-04-2003 | 12:53 PM
Default KMP P38 Engine offset?
I`m going to use Satio 72 four stroke on my KMP P38, How much offset do I use?
FLOTO
Old 11-04-2003 | 02:24 PM
My Feedback: (82)
Default RE: KMP P38 Engine offset?
Please define "offset"
do you mean the outhrust or down thrust?
Old 11-04-2003 | 03:20 PM
FLOTO:
No offset. When you have eenough offset to make any real difference flying with an engine out the offset is so great that the appearance is offensive to the eye.
Mount your engines dead away - zero-zero.
Bill.
Old 11-05-2003 | 02:07 PM
Thanks for the info, Zero offset or outhrust makes sence.
Floto
Old 11-05-2003 | 10:38 PM
SAPropbuster's Avatar
Hey, Floto, did you get an air fill valve with your '38?
How do your wing panels fit to the center pod/booms?
Does the gear covers fit to the pod/booms?
Old 11-06-2003 | 06:19 AM
Bob Severance,
No airfill valve,Ordered one from Spring Air, Cost $15.00.
One side of wing panel fit ok but the one that didn`t I used an large wood clamp to pull in the leading eadge while the 30 min. epoxy cured.
As far as I can tell by eye every thing is lined up.[8D]
Old 11-09-2003 | 10:10 PM
nemesis4u's Avatar
My Feedback: (77)
Sorry this is a bit off topic but is KMP coming out with another twin Warbird like a B-25, A-26 or P-61????? I saw it somewhere but I can't recall where and X-mas is coming!!!!!!
Old 11-09-2003 | 10:19 PM
Nemesis:
Andrew Kondor (KMP) has been selling an ARF A-26 for several years. Nice plane.
Bill.
Old 11-12-2003 | 07:35 PM
mugenkidd's Avatar
My Feedback: (94)
they are also comming out with a cessna 337, push pull twin.
Old 11-12-2003 | 07:55 PM
Michael:
The KMP Cessna 337 will be available next February, according to another thread.
Bill.
Old 11-12-2003 | 08:16 PM
After contact w.KMP, Andrew is sending me new retracts (because received were inoperable) and te air valve!
Andrew is a stand-up kinda guy! If there is any problem, I feel he will do what's right to correct the problem!!
I wish more were as conscientious!
sincerely,
