Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Multi brushless?
Old 04-09-2004 | 08:45 AM
Lucam's Avatar
Default Multi brushless?
Hi,
someone knows how to build a multi-engine plane with brushless?
Could those engines be connected in parallel, like traditional brushed ones?
I'm thinking to two brushless EDF for a GWS A-10...
Thanks!
Old 04-11-2004 | 06:41 PM
Default RE: Multi brushless?
Sorry for the delay in getting a response, I try not to let that happen.
But in answer to your question, no, you cannot run more than one motor per ESC when running brushless. If you use brushed motors, though, you can run any number you want on one ESC, up to the voltage and current limits of the ESC.
Bill.
