C 130 Herk
LA
C 130 Herk
Just info,, the Herk post have been quiet for a while,, New photos of my herk,, Can you see what is really happening to the bird in the photos.? These were flights 3 and 4 I have 22 flights todate. Take a look,, lots going on in the pics..
My Feedback: (7)
RE: C 130 Herk
Jim Great photos with the back ground. The Herk looks nice. Haven't done much on mine in a while. I extended the center section 4 in for bigger props. Hope to get more done in the next couple weeks.
LA
RE: C 130 Herk
What size engines are you going to use? Also I found on a project this big don't let it sit too long.. I tried to fly today but grass at our field was 12" high and didn't want to foul the bird in the high grass.
PS the real herk does fly ok on 3,, but on 2 at 120,000 gross wt,, it is a bear to do a landing with two engines out on one side. Then landing is very fast, for a Herk,, and no flap. If you let the bird sink on final there is/was not enough power to recover an E model.
Don't want to even try the model on 2 on one side.. Probably would make smokin hole..
RE: C 130 Herk
Jim,
I followed all the building articles you guys posted on R/C Universe. After about 1/2 way thru them I bought and built one like yours. It's all done and weighs in at 17#. I have 4 Magnum 30s ready to go. Here in Wisconsin we have had rain for a month. If it ever stops, I'll give the Herk a try. I saw your pictures in the AMA magazine. The plane looks good. I was going to paint mine like the 440th Air Wing in Milwaukee, but got no cooperation from the base. Have you got any suggestions or tips I could use for the first flight?
Bob S
Bob S
TX
RE: C 130 Herk
Very Interesting. Having flown the "ski" version of the C-130 a zillion years ago I can tell you that it will fly on two engines without a problem--two out on one side, too. At least my version would. Note that the "A" models came with three-bladed props. Years later they were modified for four-bladed props. The three-bladed version performed better.
Note that the "A" and "D" models had the pylon fuel tank outside of the outboard engines...etc.
It would be interesting to see someone do their C-130 model as a LC-130 model. For more visit www.firebirds.org
Regards, N
Regards, N
LA
First Flight with C 130 Herk
I will assume you have set the control throws up as per previous thread.
If you have a long runway I would make the first take off with 50% flaps. Don't pull the flaps up until you are at cruise altitude.
This is when I pull up the flaps, When the flaps are up you have less drag, the plane will fly faster and you can pull back the throttles.
Fly and trim as any normal plane. I also use mixing of aileron to rudder. About 1/4" deflecton of the rudder for full aileron. (this will help with engine out)
I do my landings at 50% flaps and fly a steep final approach so that if an engine quits while approaching the runway I can still land.
Also,, when you round out in the flare this plane will slow down very rapidly and drop in if you don't add a small amount of power when you flare. Just as you begin to level off prior to touch down add a little power and then take it off for touch down.
After the first flight and you have your trims / mixing set, I would take off at full 100% flaps but still land at 50%. If you land at full flaps you will slow very rapidly in the flare and drop it in.
The plane stalls very softly. But I came close to a stall when I had an engine drop rpm at take off. If you lose power on take off pull the throttle back just enough to hear engine speed change and slightly lower the nose and the plane will fly out given the engine doesn't quit totally.
Good luck and give us an update when you fly.. Jim
RE: First Flight with C 130 Herk
Jim,
Thanks for the info on my first flight. I still can't get used to using all that flap on takeoff, but I will give it a try. I guess the secret to multi engine flying is to keep all the engines running. I'm also flying a KMP P-38 and rap on wood the engines are holding up well. When the rain stops, I'll let you know how the first flight went.
Bob S
Bob S
