Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Islander
Old 11-14-2002 | 04:51 PM
Default Islander
Nothing like a web site that offers a product to be sold only to find out its been discontinued for over a month when you call them! Anybody with an Islander [unbuilt] for sale?I found one, Im trying to delete this message...MjS
Old 11-21-2002 | 07:49 PM
Default Islander
Was the company Cermark ?.If not they sell the Islander ARC.
Old 11-22-2002 | 01:55 PM
Default Islander
Found one!!!!!
Old 12-21-2002 | 05:49 PM
My Feedback: (18)
Default Islander
ANYBODY CONVERTED OVER THE CERMARK ISLANDER TO GLOW?
IF SO ANY SUGGETSTIONS....AT $123 NOT A BAD PRICE FOR A BAREBONES ARC READY TO KITBASH
I WOULD THINK (2) 20'S WOULD MORE THAN DO THE TRICK
THANKS
DAN MOFFETT
Old 12-24-2002 | 12:54 AM
My Feedback: (7)
Default Islander
Dan I have a Cermark Islander with two fox 40 two strokes . Flys good at half thro. Made new necessls so I can use 10 oz tanks if needed. This is a very forgiving plane for a twin. I w8ill fly on one motor not great but will fly.
Old 12-24-2002 | 11:46 AM
My Feedback: (18)
Default Islander
RICH
I KNEW THERE HAD TO BE SOMEONE WHO THOUGHT LIKE ME
WHAT IS YOUR THOUGHTS ON 2-25'S OR 2'30'S THUNDER TIGER?
WILL ORDER MINE TODAY!
THANKS AND BEST OF THE HOLIDAYS
DAN MOFFETT
Old 12-24-2002 | 02:38 PM
My Feedback: (7)
Default Islander
Hi Dan and Happy Hollidays to you and yours.
It is my understanding that the Islander from Cermark is no longer avaible. Maybe as not covered.
I have a friend that has two Saito 25 <i think> 4 strokes in his and it will fly if both motors are running at max. If one motor is a little off he has to find a place to park it. We fly at 6000 ft so we need a little extra. I think 53 4 strokes would be perfect. You can always thro back. This a easy ywin to fly and land. There was a thread on another Islander made in Europe and imported. Search this thread. I will be leaving for a couple days. If you have more questions I would be happy to help.
Old 12-24-2002 | 02:50 PM
My Feedback: (18)
Default Islander
RICH
GOD GAVE US A THROTTLE FOR TIMES LIKE THAT...WOULD RATHER FLY AT HALF THROTTLE THAN FULL
ANOTHER THOUGHT I HAVE IS I WANT TO HAVE A CENTRAL TANK AND FEED OUT TO THE FINGS
YOUR THOUGHTS ON THAT...........IF ONE ENGINE GOES SO WILL THE OTHER AND ALL YOU WOULD RUN IS LINES KEEPING IN MIND THAT CORRECT HORIZONTAL POSITIONING BE KEPT
I HAVE 2 -25'S WITH DIESEL HEADS PUT OUT ENOUGH FOR 2-40'S PLUS EACH AND TUNING IS ALOT EASIER AND NO BATTIERIES
YOUR THOUGHTS?
BOUGHT IT THIS MORNING ......$123 NOT A BAD PRICE FOR A TWIN ARF
CAN YOU GIVE ME A HEADS UP ON THE PEFORMANCE OF YOURS WITH THE 40'S?
ANY CLOSEUPS OF YOUR ENGINE DETAIL AVAILABLE?
BEST
DAN
Old 12-24-2002 | 04:44 PM
Default Islander
The sound of 2engines 4 stroke running togather is impressive , no way to compare with 2 stroke .give it a thought
merry x mass shakib
Old 12-24-2002 | 04:58 PM
My Feedback: (7)
Default Islander
Dan I have only seen one plane fly with Diesel . For the mess that it makes ii I personally don't want to try it. It might work fine. A single tank would work but I would use a Perry pump for each motor. and don't use a presure return from the motors. I made new Necessels and motor mounts. When I get back I will take some pic of the necessels and mount and send it to you. I thought I had some but I must have deleted them . With necessels and the Fox 40 I had to add 0 weight to ballance. Did Cermark have them back in stock?
Old 12-24-2002 | 07:57 PM
My Feedback: (18)
Default Islander
RICH
THEY JUST EMAILED ME
DISCONTINUED
IF YOU FIND ON MAYBE GIVE ME A HEADSUP
THANKS
DAN
Old 12-26-2002 | 02:16 AM
Default Islander
Dan,
I "had" an hobby hangar OV-10 on 2 os 25 diesels. Like myself, you have played with these engines for some time, and know just how forgiving they are in the tuning department. That is why I chose them for my first twin. Unfortunately on its second takeoff, a sliver of balsa that was in the right fuel tank from building, got pulled into the fuel line. I am sure you can figure the rest.
As for the one fuel tank thing. I personally wouldn't waste my time with the complexity of it. HOWEVER if you "want" to set it up for the orther engine to quit, if one goes out, just tie together your 2 muffeler pressure lines with a crossover line in the wing. Clamp off the "crossover" line for starting the engines. After they are both running right, release the clamp and fly. Now if one quits, the fuel pressure from the good engine will be bled through the exhaust of the dead engine, causing the good engine to go way too lean, and quit too.
Easy huh....
Personally I wouldn't do it. For how much power WE are dealing with, you could fly that bird back to the field on just one of those 25s
Dave
Old 12-26-2002 | 01:22 PM
My Feedback: (18)
Default Islander
DAVE
LIKE YOUR APPROACH!
I JUST THOUGHT THAT BY MOUNTING THE MAIN FUEL TANK DIRECTLY ON THE WING AND OVER THE CG AND RUNNING YOUR FUEL LINES THROUGH THE WING TO THE ENGINES. THIS WOULD MAKE FOR A SIMPLE YET EFFECTIVE SYSTEM WITHOUT MODIFYING THE WING MOUNTING AREA
DIESELS ARE GREAT...... MESSY BUT GREAT! DONT HAVE MUCH LUCK WITH CONVINCING MYSELF THAT ANYTHING BELOW A 46 IS IMPROVED BY DIESELIZING
YOU TAKE A MECOA 46 AND DIESELIZE IT AND YOU HAVE ONE OF THE MOST USER FRIENDLY AND POWERFUL ENGINES POUND FOR POUND PERIOD. AND INEXPENSIVE AS WELL
I'VE GONE TO MAKING MY OWN CAPS AND MODIFIED THEM TO BE ALOT MORE USER FRIENDLY THAN DAVIS DESIGN
BEST
DAN
Old 12-26-2002 | 04:57 PM
Default islanders
Dan, My islander has a pair of Saito .56s firewalled to the main spar and reinforced all around. Two perry pumps go to one 16 0z tank on center with main spar in body, vented to the bottom of body, useing original fiberglass nacelles, reinforced main gear, seperate flaps with aileron servos in the wing. Top it all off with an Air Jamaica ultricote scheme, Very impressive,Wifes favorite. Trying to get photos posted on this site for you guys. Stay in touch, MJS
Old 12-26-2002 | 05:15 PM
My Feedback: (18)
Default Islander
MJS
I THOUGHT THERE HAD TO BE A BETTER IDEA
GOT THE LAST ISLANDER NIB
$160
DAN
Old 10-26-2003 | 08:15 PM
Default RE: Islander
Old 06-22-2005 | 03:20 PM
mr.scale's Avatar
I might fly it this weekend for the first time (2 TT36pro).wish me luck! (june 25th 05)
peque
Old 06-22-2005 | 09:22 PM
My Feedback: (7)
peque good luck with your maiden. I am still flying mine. It is a very forgiving twin to fly. Engine out is no problem, just turn with the rudder and land. I see you are from Bellingham WS. I lost a real good friend from there last year from lung canser. Rich
Old 06-23-2005 | 03:33 AM
mr.scale's Avatar
Sorry to hear that[&o]
I let you know how was the maiden flight on sunday or so!
this is my second twin!
Peque
Old 06-23-2005 | 08:29 AM
IWC
R/C Model World July 2004 issue has a Long-Nose Islander (Twin) 600 size EP. Plans Available
I also have a factory hand drawn 3-view of this aircraft.
[email protected] (email)
There is an European kit (I.C.) available of the miltary version of the islander. I cannot think of the name. I found it a while back using google.
www.espritmodel.com has an EP Islander
I have plans for a FF EP Trislander
Old 07-04-2005 | 03:49 AM
mr.scale's Avatar
I flew mine (maiden) after a few days on working on the engines finally today i worked on them for the last 4hrs more I don't know if because they're upsidedown or the fuel line is too long from the tanks, one kept on quiting and with the help of my buddy we got them to run some what ok! Well it flew for about 30sec and the starboard engine quit!! i reduce power and turn around and land it, and the first thin in my mind was to conver this thing to electric. some one suggested a pair of check valves on the fuel lines!
I'm open for any of your tips!!
peque
Old 07-04-2005 | 10:54 AM
My Feedback: (7)
peque I made square necessels andmounted the engines sideways. I put an 8 oz tank in each of the nessels. I haven't had a fuel problem at all,. Rich
Old 07-04-2005 | 11:53 AM
mr.scale's Avatar
baldeagle: you mean muffler pointing down and the tanks mounted on the wing behind the engines? If you have a picture of it,I like to see your set up?
thanks!
peque
Old 07-04-2005 | 09:09 PM
My Feedback: (7)
Peque here is some pic without the cowls. I plan on taking the Fox 40 two strokes out and putting some 52 four strokes.
ID:	293696   Click image for larger version
Old 07-04-2005 | 10:02 PM
mr.scale's Avatar
Rich: thanks for the pics i'll get to work on this engine configuration and i'll let you know when i'm done! and i post some pics of it!
thanks again!!
peque
