Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 Don Smith B-29 question >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 07-02-2006 | 05:31 PM
Default Don Smith B-29 question
I am getting ready to start my 5 year plan to build the 141"b-29 from ds plans.After looking at them for a while this afternoon,the first question I have is what is with the rudder horn?I understand the hinges .It is a pice of 1/8 wire that runs the lenght of the rudder,thru 2 pivot points made of aluminum or fiberglass or phenelic material inside a plastic tube,do not know why a plastic tube would be used unless to try to cut down friction.but then it shows what looks like a tube over the wire with the rudder horn on it.know the only way this is going to turn that rudder is if that wire is epoxied securly to it.anyone that has built one of these could you please enlighten me a bit on this part of the contruction.Thanks
Old 07-02-2006 | 05:52 PM
Default RE: Don Smith B-29 question
Can't help you but if you take a pic of the plans in that area and post it someone might be able to figure it out.
Old 07-02-2006 | 06:14 PM
If they built from the plans then they will know what I am referring too.I want advice from an actual builder.
Old 07-03-2006 | 04:56 PM
Hi man ,
If you can put a pictures oh the place of the to have am idea which his problem .....
Sergio(JOCA)[sm=thumbup.gif]
I have plans B-17 DS plans maybe can help ........[sm=cool.gif]
Regards
Old 07-03-2006 | 05:33 PM
TLH101's Avatar
My Feedback: (90)
ORIGINAL: aerowoof
It's not real likely you will find a lot of builders of this model. It is a "major" undertaking for even the most dedicated modeler. BB Webber at Bomber Field has built 2 of them over the last 10 years.
Old 07-04-2006 | 01:05 PM
I have the D.S b-17 plans also and the rudder setup is almost the same ,take a look at your b-17 plans and see what you think.
Old 07-04-2006 | 10:46 PM
Ive got the 169" plans and it looks like old style hinging. 1/8" music wire soldered to a brass tube and the tube is most likely epoxied to the three lower ribs. Though you could probably make it removable using wheel collars to lock the wire into place. Just a thought...
Old 07-06-2006 | 10:02 PM
My Feedback: (16)
hi. if it helps i built ds b17 the rudder is the same with 1/8wire with hinges the tube is just a out line on the plans what i did was built the wire into the leaningedg grove to fit . on the bottom of the rudder 3or 4'' i used the plastic tube to go in to fus like a bearing holder and conected the horn it works fine only thing you cant take the rudder off 1/8 wire came about 18''long with 6'' in to the fus my b17 will fly in august its on rcu 138 ws ds good luck
