Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 Part# needed for reverse cams >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 08-19-2006 | 10:40 PM
My Feedback: (51)
Default Part# needed for reverse cams
Guys,
I have two projects underway. I have a bronco & B-25 on thier way. The Bronco (my second one - crashed the first due to structual failure) uses two Saito 40's. The B-25 is a Ziroli 101" which will use two Saito 125's. I'd like to find out if Saito makes the reverse cams for these two so I can have opposing engines. If anyone knows if they make the reverse cams PLEASE confirm with a part#.
Thanks a million guys!
Old 08-19-2006 | 11:24 PM
Default RE: Part# needed for reverse cams
osxpro:
I know of no reverse cam for the FA-30 or FA-40, sorry.
The FA-125 does have one available though, SAI182TD34 which should also gat a new set of tappets, SAI 5038, to go with the new cam shaft.
The SAI182TD34 fits all Saitos from the FA-56 up to the FA-100 also, you might see if it could be adapted to the FA-40, and let us know.
Bill.
