KMP F-7F Tigercat
#1779
RE: KMP F-7F Tigercat
ORIGINAL: Capt G
Here's how i did the KMP. Just used a 1/4 20 bolt and blind nut which both secures the outer wing panel and acts as an anti-rotation pin. Access is through the main gear well.
#1781
Brett, did you re-enforce the mid section of the wing on your ? if I remember you had a KMP early version with composite wing like Greg and I
Tom
Tom
#1782
Tom, I have the ESM version with the built up wing. I didnt re-inforce the wing at all as it only seemed to be the early composite wings had strength issues.
My next project is also a P40 but the 50cc ESM version. ITS FRIKKIN HUGE!
#1784
Greetings from Ireland!
Just starting out on my KMP /ESM / YT Tigercat, this is a great forum, going to attempt all the Col Winters mods but building the following format:
E-flight 160 setup as per Greg Covey - Ampd review with dual 10S
85A CC ESC
Sierra Retracts
Futaba everything 3305's mainly with 3003's for flaps, 3317's for each gear door and jetronics sequencer.
Going for deep cockpit kit and gloss automotive outer protective coat.
I will post pictures and try to avoid the pitfalls, aiming for 25lb-ish weight.
85A CC ESC
Sierra Retracts
#1785
Good luck with the build! Will be great if you can get it under 30lbs, especially with extra paint, doors, cockpit etc. Dont worry too much if it gets to 30lbs as they still fly great at that loading.
Cheers
Brett
Cheers
Brett
#1788
My Feedback: (8)
Thanks for the info STOAT, since my last post I have located and purchased an original KMP all composite Tigercat from a hobby shop in Oregon. Gus, with KMP told me there was a store somewhere in oregon that had sold KMP products so I did the search and found the guy. He had one left in the blue finish. Ill post photos when I get it Here is my first Tcat that met the spiral of death[] I did a three piece wing mod. on it
#1790
My Feedback: (8)
it will be perfect, with the g26 zenoahs i had to ad 2 oz of lead to the tail, which isnt much, so you may have to add a small amount to the nose. Otherwise, sounds like a winning combo...the plane cooks with the 26cc, it will be blistering with the 30cc
"Go low if you wanna make a show"
Jimmy
Jimmy
#1792
My Feedback: (66)
N86 i grew up in Rogers and went to RHS. I am not sure on the gear yet. 850 for gear and brakes seem a very high price tag. i can get the ESM gear, gear doors and brakes for the cost of the Sierra gear alone at 650. They Sierra gear is more scale looking and the ESM isnt a real scale plane. i havent decieded yet. i would like to stay under 2000 total with the 30's and digital servo's. i can do that with the ESM gear.
All you guys that have the GEN 5 ESM gear has there been any problems with them? i havent went back and read everything in here lately. it would be nice if there was a sticky with all the major details lol.
I will put all control linkages in the plane if suitable. i will fly this plane fast and hard also. how is the Built up wing holding up?
#1793
The setup you are looking at is exactly what I have in mine (except I have EVO 26's). I have had lots of flying and no problems so far. The gear does need some maintainance from time to time and will require stripping and loctiting before use.
The built up wing is easily strong enough (as my flying on you tube will show!) and all up weight comes out at 26 lbs. I havent worried about breaks, but have just installed gear doors and has made it even faster! Easily the best plane I own!
#1796
Jimmy,
My landing gears made from Shindin it looks not beautiful like Sierra but they're very strong I paid $400 for nose and main gears, here is the link for the pictures
[link=http://www.shindinmachine.com/pilotprojects2010.html]Shindin Machine[/link]
