KMP F-7F Tigercat
#2201
My Feedback: (31)
I have had a pilot on back order from TBM for months - no joy, so would someone please advise the height and width of the pilot you used so I can try to source one of the proper size elsewhere? Thank you.
Anyone??
Anyone??
#2202
http://www.magnumrc.com/RC-Pilots_c_18.html
http://www.magnumrc.com/ESM--F7F-Tig...kpit_p_60.html
#2204
Hi Airman 98. I am putting a Smoke System in my ESM T-28. I will put a smoke system in my Tigercat after I learn more about the smoke system set-up. The question I have is : What size hole do you have in the muffler fitting? I am using a Zenoah G45. The pressure fitting in the muffler has a hole .040. I think that may be too small for the amount of smoke fluid I will need for a good smoke trail. What size holes do you have in your Tigercat mufflers. I have 2 - 16oz tanks in my T-28. This should give me many minutes of "On Time" Are you mixing your own Smoke Fluid? Thanks, Col. Chuck Winter
#2205
Go here, you have to paint them, but they are posable. The ESM Pilots are 1/6 scale.
#2206
My Feedback: (24)
I've been going through the entire thread again, but did not see that anyone else had this problem: The fit between the nacelles and the middle wing is angled, with a large gap at the trailing edge of the wing. There is a 1/8" gap on the port side and a 3/32" gap on stbd. The plane is brand new from ARF Pros and it's the built up wing. Anyone experienced this??
Would someone mind measuring the distance from the stock main retract mount (wood mount), to the axle...main gear only. ESM and Sierra gear would be much appreciated. Playing around with a few ideas
Mike
#2207
My kit came the same way,with 6 inch split bottom rear of fuselage.Had to take and send them pictures.Then they didnt have any shiny in stock so I told them to send matt replacement.they said just clear it.I can paint ok but with the spray cans it looks bad,I need to take it to a pro..I have ESM gear and from wood mount to middle of axle is 8.5 inch.Dean
#2208
My Feedback: (24)
Thanks Dean
#2209
TX
After almost two months, they finally replaced my middle wing section. The fit is much better. Only needs some minor clean-up for a near perfect fit. On with assembly.
#2210
My Feedback: (24)
I pulled the kit back out yesterday, and gap between nacelle to inner wing was 3/32 on one side, and 1/16" gap on the other side, and one outboard wing panel was too far fwd by 1/8". Called TBM, no stock, no date. Told me to go ahead a modify it knowing they will have more at some point. I said if I modify it, I own it, he said you already own it. Guess its a tail light warranty...LOL.
No no only kidding, he did say that, but after that he said take pictures and they would submit to ESM for warranty replacement
On with the mods!
On with the mods!
#2212
TX
I'm ready to take mine out to the field for some taxi testing and engine tuning. Not quite sure how I'm going to get it there though. Can't decide on how to stuff it into my Expedition. Anyone have some pics to share on how they transport theirs?
My Feedback: (10)
TX
I don't have pics, but 2" thick EPP foam cradles work great for mine.
Just cut to match the airfoil and store the wing props down for transport. Make em tall enough to just clear the prop hubs. The wider the better for the cradle foam because you can smoosh the Leading Edge if it is too narrow....
Do the same for the fuse and make the cradle tall enough that when you put the wing on the fuse the gear will not touch (or will barely touch). Then you can swing the gear for your pre-flight....
#2214
My Feedback: (10)
TX
Why not just put a bead of filler (or black silicon like we used) around the rib and push the wing panels together and then file off anything that oozes out? Its just to fill a gap and won't weigh much.... A tiny bit of touch up paint and away you go in less than 30-minutes???
On with the mods!
On with the mods!
#2215
TX
Thought about that but travelling with the props facing down worries me that the clunks might get shook up enough to bend back on themselves and get stuck forward. But cutting up a couple of foam coolers to match the bottom airfoil and the bottom of the fuse might just do the trick.
Hi Tiger Cat Fans. Just had a GREAT weekend flying at Castle Airport during the IMAA West Coast Festival. My F7F was a HIT at the IMAA Festival again and the SMOKE trailing out of each engine during large smooth loops, Cuban Eights and high speed runs were crowd pleasers. My 2 Fuji engines were HUMMING. I had many people come up to me after my flights with many question and comments how BEAUTIFUL the airplane looked with TWIN smoke trails through all the maneuvers. I hope that some of my flying will be in a Video that should be out in a few months. Col. Chuck Winter
#2222
http://youtu.be/eh6YFDiUH6I
This is one of my flights at the IMAA event last weekend. Great SMOKE from both engines. Col. Chuck Winter
#2225
Tiger Cat Fans ---- Just lost all my answers to all your questions -- RC Universe did it again. I'll post a picture and then Post another picture. This may take a few posts. Chuck
