Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Matched engine speed
Old 01-22-2003 | 12:25 AM
WLJ's Avatar
WLJ
My Feedback: (108)
Default Matched engine speed
First Twin, C-160, OS46 2 strokes. How close in RPM do engines need to run, and do you turn INTO or AWAY FROM engine out? Thanks, WLJ
Old 01-22-2003 | 12:42 AM
Flyfalcons's Avatar
Turn away from the dead engine.
Old 01-22-2003 | 01:48 AM
JohnBuckner's Avatar
Also Rudder into the good engine for the remainder of the flight untill power reduction for the landing.
John
Old 01-22-2003 | 04:09 AM
Default Engine RPM
I try to get the engines on my Duelist (OS 46's) within 300-400 RPM of each other at about 2/3 throttle. Even a 500 rpm difference is barely noticeable in the air. I have flown it with as much as a 1000 rpm difference, which definitely made the plane pull to one side, but a little rudder trim took care of it.
Once I accidentally flew it with a 10-8 prop on one engine and a 10-7 on the other. I was amazed at how noticeable that was! Even though I'd sync'd the engines pretty good the plane really wanted to turn on me once airborne.
I got hung up on trying to sync my engines when I first got the plane (even bought a tach that I now barely use) but soon realized that it's more important to get them running good and reliably (usually on the rich side). I then just stand in front of the plane and listen to the sound as I run the engines up - if you get a "warbling" sound instead of a constant "drone" they're too far out out of sync and need adjusting.
Good luck with your twin!
Jim
Old 01-22-2003 | 10:50 PM
WLJ's Avatar
WLJ
My Feedback: (108)
Default Thanks
I really appreciate the information. I think i'm going to like twins. Got my eye on a OV-10. WLJ
Old 01-23-2003 | 02:44 PM
mulligan's Avatar
Before matching engines, don't forget to match props!! Otherwise, matching engine RPMs is meaningless.
Take a few props (of the same size, Jim ), and run them on the same engine at full throttle. Match the props in pairs that have the closest RPMs.
- George
Old 01-23-2003 | 11:06 PM
DICKEYBIRD's Avatar
I go one step further on my small engine powered twin. If they just don't sound right in the air, I have swapped props from one side to the other and got a "sweeter" sounding match.
Old 01-23-2003 | 11:10 PM
mulligan's Avatar
Cox-a-holics???
Sheesh, you'd think they'd come up with something a little different
- George
Old 01-23-2003 | 11:20 PM
DICKEYBIRD's Avatar
Say what?? You lost me.
Old 01-23-2003 | 11:35 PM
mulligan's Avatar
I'm reading your Avatar COX logo, wherein it states, "Cox-a-holics Anonymous"
Seems, ahem, provocative.
- George
Old 01-23-2003 | 11:49 PM
DICKEYBIRD's Avatar
Naah, I just love the little bastids. That's what I started the hobby with uhhh, 44 years ago: Cox .049's. I have gone full circle, all the way up to 1/3 scale with biggie engines and now have nostalgically reverted back to Cox; where I started!
There's a group of us that have learned how to tame them and make reliable runners out of them. I just call it "Cox-a-holics Anonymous" and whimsically made up the logo and use it as my avatar. I guess those with a perverted side might read something else into it but hey, check the spelling!
Old 01-24-2003 | 12:13 AM
Naaww Don,t listen to em Dickeybird, I love the logo and there are still plenty of us lovers of the finer mechanical things in life left.
John
Old 01-24-2003 | 01:08 PM
DICKEYBIRD's Avatar
Amen brother!
