nitro model B25
RE: nitro model B25
Hi Tom, both of these motors came out of crashed helis. I had them laying around and thought wow I could do a twin with these motors. Hacker later said one of them had a short in one of the windings. It would be better to start with new motors , controllers and batteries.
Mark
Mark
MI
RE: nitro model B25
Hey mark, if you are putting some down into it to make it fly level, and you made it a tad tail heavy, wouldnt adding some nose weight help with the elevator setting? Im getting ready to work on last details and really am interested in what you have to say on CG since the instructions are useless. Right now I would say Im where you are, just a hint of tail heavyness. I like a model to tip foward just a tad. Side to side Im very well balanced. Oh I ended up putting a foam shield between the wires and the main wing tube (aluminum) as it was effecting my radio. Im getting ready for the next test run of the engines in their new position. Hopefully I can get the glow drivers to work this time.
Dan
Dan
RE: nitro model B25
Dan, I made it a tad nose heavy. It calls for the cg to be 4 1/2 inches. It was tail heavy and I barely got it down ballanced there. Mines between 3 1/2 to 4 inches now. I also shimmed up the trailing edge of the elevator 1/8 so I wouldnt need so much up elevator. I made a mistake on my earlier post. It needs a lot of up elevator to fly level.
Mark
Mark
RE: nitro model B25
Bought a Nitro B-25 at the local hobby shop today, I'll be taking it back tomorrow and that's a 200 mile round trip. That's how bad this POS is. I don't want it soiling the air I breath. We did take it out of the box but not out of the sealed plastic and thin foam that completely hides the structure. The top and bottom of the fues is 0 2 thin that is split, crushed, crooked and horribly scalloped then soaked with ca to hold it all together. I didn't save 260 bucks by not buying the kmp I wasted 260 when I bought this box of firewood. No it wasn't damaged in shipping.
#31
GA
RE: nitro model B25
Hey Dan,
Just wondered if you had finished and maybe had a couple of flights already? I have not work on mine in a while but plan getting back on it soon. Has anyone else out there flown this plane yet?
Mark
Mark
#36
RE: nitro model B25
Well for a $ 250 arf, good reveiws way out numbering the 1 bad job, I would rate it very high.
And 1 crash job rated a instant new one. Sounds very good to me.
All kits are not always perfect. Neither are all modelers.
#37
AZ
RE: nitro model B25
No I did not take any pic. I hope to have it back by next year. It has never been flown so I waiting to see how the 2 os 46 will do on this plane.
ORIGINAL: plane mike
Patzane
Do you have any pics of the install?? I think I have it worked out, but I would like to see how someone else did it.
thanks
Plane Mike
Patzane
thanks
Plane Mike
#38
OH
RE: nitro model B25
ORIGINAL: DansAm
Dan
Dan
I am interested to know about the "Glow Drivers" you used and how they worked. Can you send a website to look at?
Denny
#39
OH
RE: nitro model B25
ORIGINAL: nchouker
guys,
we are working on the newer version of our b-17,it's much improved,we will keep u posted once we get the newer version available.
guys,
nchouker,
Have not seen you back on this forum in a while. Have you guys got a newer version of the B-17 yet and wherecan a person look at and buy them?
Denny
#44
AZ
RE: nitro model B25
did the madien flight today on the B-25. All went well. The retracts did not work well but I was able to labd her safety with no damager. Have to do some 1st flight changes but that is very normal. Did do some video, but think I will post up later after I get more video. Will try to get things fix by Friday and have her up in the air this Sat.
#46
AZ
RE: nitro model B25
I started with Hobbico mechanical retracts. I had a servo for each retract. I order a set for Spring Air #102HD. Just received this Wed and started to put them in today. Retract are well build and can handle up to 15 lbs. My B25 weigh in at 11lbs 12oz.
#47
AZ
RE: nitro model B25
Finish putting in the Spring Air 102 HD. Very nice setup and put pull-pull for nose wheel. Final weight with air retect is 12 lbs 7oz. Will post pics later. I had to send my radio in for repair so waiting to get that back to get this baby back up in the air.
#48
AZ
RE: nitro model B25
here is a short video of the Madien Flight about 1 month ago. http://www.youtube.com/watch?v=dcj5L4W51QE
#49
AZ
RE: nitro model B25
Was able to put 3 more flight on the B-25 today. The 2 Evolution 46 handle this plane well. Most of the flying is done with under 1/2 throttle. The spring air retract and handing this plane well.
#50
RE: nitro model B25
DansAm trust me on this one DON"T USE THE 52s ON THIS BIRD[:'(] . I used them on my Wing B-25 and was very under powered. Have since rebuild and am using a couple of SK 70 two strokers but you mite want to use a couple 70 fourstrokers. Just a little experience talking they now resides inside my P-38 and are pulling it just fine for me that is.
