Top Flite Cessna 310 posted
#1779
My Feedback: (37)
RE: Top Flite Cessna 310 posted
ORIGINAL: handyman_alw_
Hey Dickie,
If you got any more pictures from the weekend of the other two 310's or mor of the top-flite one would you burn them to a cd for me and i will pick them up from you on monday wherever we are flying. Thanks
Allen
Hey Dickie,
Allen
Danny Gable was taking a bunch of photos at the event. I have asked him to send them to me and will either post or burn a CD for you.
Gaines
#1781
ORIGINAL: Bo Ingram
Allen...just an observation...
Since that is not a very detailed cockpit, it would be pretty easy to fabricate. The pilot bust is now offered by Hangar 9 (?) at my LHS for 12 bucks.
Bo
Bo
#1782
My Feedback: (14)
AR
Gaines,
I went ahead and just ordered a new kit yesterday buy the time i was to get all the parts for just the wing i was already at $ 420.00 or so . I will be sending the rec in when we get back from this next trip to see if there was anything there and to have it put over to a higher channel just in case.Hope to see you on monday at the hill.
Allen
Allen
#1784
This is not fair!! I cant order T's from McMaster-Carr... I am in europe and they wont ship here, and ideas on where else I may be able to find T-connectors?
Rob
Rob
#1787
aha thank you! my OS .55AX Engines + Servos + stuff all arrived today.. Retracts shipped today too! looking forward to the weekend!
#1788
Hi all,
happy to report that i have my Cessna 310 arriving soon. been following this thread very carefully but would like to ask you a few questions...
i will be cutting off the nose and modifying it to be a "R" model.... ( longer nose) and repainrting it to follow my father's Cessna 310R ( full size aircraft! )
My Question is ,
1.is the model painted in the mould or is it externally painted!!!
2. how much lead is in the nose of the aircraft.
many Thanks!
michael
My Question is ,
many Thanks!
michael
#1789
ORIGINAL: citation560v
Hi all,
My Question is ,
many Thanks!
michael
Hi all,
My Question is ,
many Thanks!
michael
#1790
My Feedback: (34)
Hi all,
My Question is ,
many Thanks!
michael
Hi all,
My Question is ,
many Thanks!
michael
It's not paint, it's gelcoat. At least the White is. The blue is paint, I think. It shouldn't be a problem if you carefully sand the entire fuse with 220 grit. I was thinking of covering the entire airplane with flite-metal. Just to make it diffrent from everyone else.
#1791
Hi Guy's,
just spent 2 hrs reading all these posts. I am in the UK and cannot find anyone who stocks this kit, Ripmax are listed as a supplier but do not stock it.
I did not see any posts from the UK claiming to have one.
Any ideas how i could get one ?
On a slightly simpler note.. could someone tell me what size hex/allen key the bolts used for the engines mounts take?? I've tried every metric & imperial size that I can find but no luck
alans: i bought mine from towerhobbies, shipping cost was $199 though!
#1794
Well, today was a fantastic day. A little breeze going right down the runway and a perfect maiden flight. My OS 50 powered 310 with Spektrum radio flew perfectly. Eased it onto the runway, gave it throttle and just a lttle up elevator and it was in the air in about 100', just a couple clicks left and was flying hands off. Balance was perfect and it just handled great. Did some loops, rolls, low high speed passes, very impressive....everyone in the pitts was watching. Tried the flaps but it ballooned so I need to mix some elevator with them. Came in for landing approach, flair, now I applied flaps and it was down.....just perfect. I can not be more happy, Top Flight has provided a great ARF. Made several more flights and went home a happy flier.
R/C Foolish
R/C Foolish
#1795
My Feedback: (7)
Well, I too am happy to report that I had my first flight on my 310 today. Mine is powered by OS 70 Ultimate 4 strokes and they run strong pulling a 13x7 APC at 10K. Unfortunately, on the 3rd flight at 1/2 power ( flys very fast at 1/2 power), one of the engines quit. I had just turned downwind and was about 100 ft up. I went to full throttle and maintained level flight with some aleron and rudder and the plane began to pick up airspeed. When I had sufficient airspeed (control was increased with air across the vertical stab), I cut the powerto 1/2 and turned onto final. Then went to 1/4 throttle and no flaps for an excellent landing. In fact, my best landing today was with the one engine.
It was a great day!
Also, with a rx and lights battery, I did not have to do anything for it to balance correctly. What a great ARF.
Jim G
It was a great day!
Jim G
#1796
My Feedback: (13)
PA
I recently swapped out the landing light with a 3 L.E.D. flashlight assembly. What a difference, even in the daylight. I'll post some pics when I get it together at the field but in the mean time you can see how bright it is. I made the hatch hinged to be able to get behind the light to remove the stock one and install the new one and to store the battery.
#1797
After watching the following video I am trying to decide if an engine went out or was it a tip stall. Any ideas ??
http://www.rcuvideos.com/item/TQPPYV0802851HK3
#1798
Hello i think is it a engin out plane turn to the right speed ok,no ving stall,the same happen to my flying a l-200 morava in the landing [sm=49_49.gif] best regards olav rygg
#1799
Sussex Model Centre in the UK have them listed on their site:
http://www.sussex-model-centre.co.uk...d.asp?id=22249
but they want £495 ($980) for it
