Any good smaller kits out there?
RE: Any good smaller kits out there?
-Check out Hobby Hangar's 52" OV-10 Bronco (Rich Uravitch's design). It takes time to build, but it's not difficult. If you have a couple of kits under your belt, you shouldn't have any problems. I have OS 25FX 2S motors on mine and it has nearly 1:1 static thrust to weight;. The Saito 30 engines should be a great match.
-The Twinstar is probably a little better twin trainer, but the Bronco looks much better and it taught me much about twins. As a matter of fact after many years, it still flies great.
