Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Topflite DC3 c of g
Old 02-07-2008 | 03:54 AM
Default Topflite DC3 c of g
Has anybody had a problem with the c of g as recommended in the instruction manual. The 2 x 10 oz tanks are behind the c of g and weigh 28 oz (0.8 kg) when full.
Old 02-07-2008 | 01:57 PM
fliir's Avatar
Default RE: Topflite DC3 c of g
Everyone I know has balanced it per the manual. I have never heard of a stablility problem at the mandated CG.
BTW - there is a nice article on the development of that design here:
http://www.top-flite.com/reviews/topa0500-rcr.html
Old 02-08-2008 | 10:36 PM
My DC 3 has tanks mounted behind the cg in the center section of the wing due to installing retracts, I balanced with full tanks, I did lots of research on this topic a year ago and I am glad I did. You do not whant to take this plane off tail heavy. I have around 30 flights on it and it flys great with this cg even on one engine. Have fun.
Old 02-09-2008 | 04:17 AM
Thank you for your replies fellars. My set up is the same as n9331v and I have come to the same conclusion.I found with full tanks the c of g moved back 5-6 mm so I have added 58 gm in the nose. The reason for my post was a problem on the test flight about 2 weeks ago. After 2 laps of the field at half throttle to trim, the aircraft was positioned for a 30 degree climb with full throttle after which it increased to about 60 degrees with no further control imput. It dropped a wing and entered a spin of 2 turns pulling out about 15 from the ground. Needless to say I landed immediatly thinking something had shifted back but nothing was evident. I have not attempted to fly it since. I just find it strange that the instruction manual tells you to balance with empty tanks ?
