eflite p-38 throttle differential
ESC's plugged into different channels?
Then it will depend on what Tx you are running.
Master - Rudder, Slave - throttle then its a matter of selecting an activating switch and mixing right rudder to left engine increase and vice versa.
I'd imagine that it's exactly like doing it with gas or glow. Just plug the ESC's in to two channels instead of the throttle servos, and follow any of the various "how-to" posts on here. My JR 9303 has a twin engine feature, and it works just fine on ESCs as on throttle servos.
