buying a twinstar need engine advice
My Feedback: (40)
I'm ordering a twinstar, and would like some input on engines...I would rather not spend the money for a pair of OS 25FX engines...i was considering these as a possiblility...kinda leaning the OS 25La, magnum or supertiger
OS25LA
Magnum 28
Supertiger 34
GMS 25 or 32
thundertiger GP 28
OS25LA
Magnum 28
Supertiger 34
GMS 25 or 32
thundertiger GP 28
RE: buying a twinstar need engine advice
Of my .25 powered multi's which includes two twins a quad and and a Six Pack I have been in the process of converting over from prior cheaper engines to new .25FX's, almost there now (with tremendous results in terms of enjoying my flights) with only my latest and uncompleted one to go a scale triple and it will get .25FX's.
The engines that were replaced included Magnum .28's, Magnum .30FS and two were TT 28GP
Sorry not what you wanted to hear but The little FX remains absolutely the best for the application than anything in my opinion and has absolutely the best Throttle response and user friendliness for a multi, and that of course is just my opinion.
Have seen a lot of dispair when folks try to economise on engines, a poor plan with glow powered multi's.
John
John
I went from OS.25fp to TT.36, and now to OS.40FS 4-strokes. The TT.36 were great fun, but you have to be mindfull of the stresses put on the airframe. It was the fastest plane at the field for about a year. After one season with the TT.36 I had cracks in the both firewal glue joints and stress cracks in the wing sheeting in the center section. I fixed it by glassing with 2 oz cloth out to nacels top and bottom and used triangle stock to reinforce the fire walls. Flew the covering literally off the plane. So I recovered it with solartex. I'm on my third covering job now and will be using ultracoat and putting retracts in the wing, replaceing the last of the plastic with wood block or make my own fiberglass parts. I had to go to dual aileron servoes to cure a flutter problem at high speed.
Edwin
Edwin
My Feedback: (40)
my girl friend just ordered me a pair of the Magnum 28 2-strokes for the airplane...I guess I'm stuck with them....oh well...free is a good price
My Feedback: (40)
John~
Yeah you're right, can't beat the price...and one hell of a girlfriend to support, let alone fund a hobby. What are the advantages I'm missing by not going OS?
ORIGINAL: dschroeder
John~
John~
With the Magnums it seems to be consistancy is what is missing some are good and it seems others less so. While they put out about the same power where they are weak is throttling and consistant response. Its possibly the carbs poor quality control that causes this.
With the four engine airplane and mag 28's considerable time was spent every time getting them just right but not always successful. The FX's are far more carefree in that respect and much time is saved and more flying.
I did at one time with the Quad have one of the mags blow out a large hole in the bottom of the crankcase. For unknown reasons. That was at about 100 flights with that airplane which is now close to 200 flights and I did convert over to FX at about 180 flights. Much happier with them and the flights more enjoyable.
John
My Feedback: (24)
AZ
DS,
I have had my twinstar for two years and many flights. I power it with two os .25FP's. The 25Fp's are very similar to the OS LA engine. Mine flys beautifully with the OS .25fp's and it is fast.The engines are in good shape and very reliable. Although the Twinstar will fly on one engine easily. I had one engine out in the two years of flying this Twinstar. I didn't realize I had lost an engine until I tried to turn into it. It wouldn't turn in that direction, so I turned the other way, held some rudder and landed without stress. I don't know why anyone needs to put bigger or faster engines on the Twinstar because it is fast with the Fp .25's. Besides it has only 4 Oz. tanks Best advice I can give you is to use the La .25's, tune them individually so they run properly. Don't try to tune one to match the other. You increase the risk of engine out if you try to match one to the other. A few hundred RPM difference will not affect flying. Mine sound close but are not exactly synched at all speed ranges. If you really want that effect I would suggest purchasing a "Twinsynch" unit. It might be an over kill on a Twinstar.
Good luck, and let us know how you make out.
Gerry
Gerry
Yep, the twinstar is a great twin trainer. After I re-engined mine I had an engine out right after takeoff, and then had a throttle linkage problem on the other engine. There I am with an engine out and the other stuck at wide open throttle. I just ran the fuel out and landed. That says more about the plane than my flying abilities.
Ediwn
Ediwn
My Feedback: (24)
AZ
MX240,
It has been two years since I first flew the Twinstar but I did have to tone down the ailerons also. Basically I limited the end points and that cured the sensitivity for me. After that nothing more required.
Gerry
Gerry
