RCU Forums
-   Twin & Multi Engine RC Aircraft (https://www.rcuniverse.com/forum/twin-multi-engine-rc-aircraft-192/)
-   -   Servos? (https://www.rcuniverse.com/forum/twin-multi-engine-rc-aircraft-192/10118409-servos.html)
basketcase118 11-06-2010 07:25 AM
Servos?
Hi
I need some help. I dont know how big of servos I need to build this B 29. It has a 169 inch wingspan.
The flaps are about 28 inch`s long, I have four on the wing, two on each side. the plan calls for one servo each, the elevator is 51 inch`s and it calls for one servo. the rudder is 20 inch`s, one servo. I sure could use some help Rick
91zulu 11-08-2010 05:53 PM
RE: Servos?
http://servocity.com/html/hs-805bb_mega_power.html
If you want you can use these and all you will need is one on each surface..
Or you can go the digital route and over spend. Bigger servos + bigger gears = more strength. For that size plane I would go with the large servos.
basketcase118 11-08-2010 09:01 PM
RE: Servos?
Thanks, I see These Have A lot more torque than some I Have seen. and the price is great.
91zulu 11-08-2010 10:18 PM
RE: Servos?
Yes they do. But don`t worry you may get a flood of replies telling you to use digital servos at 2x and 3x the cost. I`m surprise they are not posting yet...
