modifying a trainer to twin
What to do with an old trainer....
RE: modifying a trainer to twin
1 Attachment(s)
pics
1 Attachment(s)
more pics
1 Attachment(s)
finished
need some covering |
1 Attachment(s)
test fly day at the field.
nice use of some old wood!
Questions: when you cut in the pods for the engines - did you end up with a longer wing or just cut out '1 bay'? how much tail weight did you need to get a good cg? any thought to a foam nose? or maybe a single ply of glass to cut weight? any thought to rotating the engines about 45 degrees (space allowing) and get the mufflers tucked under the wing? Comments: Fantastic job! Great color choices on the covering So how does she fly??!! |
ooh, looks pretty good :) may have to try that when i outgrow my trainer...
what does it fly like and what engines you using? |
1 Attachment(s)
If you don't want to build up a new nose the Twinstar fiberglass nose works on the Tower/ Hobbico Trainer....
that takes some balls - 4 engines held with rubber bands!![X(]
Nice mod! |
Hi
1. I left the wing at its original size. 2. since the engines are located near the CG point no extra tail weight was needed. 3. The engines are two old supertiger 0.40 that i had. 4. She flys great , very fast and the sound is amazing. |
What a neat project!! Coverting it to low wing was a nice touch, although it involved a lot more work on your part. It looks great!!
Man, you work fast! (that is if the dates in the pictures are right) Very impressive and nice work!
1 Attachment(s)
If you make the front end pointy most guys will land & give you the air space;)
Hi
If I may ask , why did you make it a low wing ? Nice project , well done Michel ( Mike ) ;)[8D] |
LOL :D
I like the space needle approach and attitude Scote! I always wondered how to get more stick time - now I know! |
wow !!!
cool ultra stick What engines are did you use ? btw... the dates on the pictures are correct. Hi mike low wing just cos it looks better ;) |
Ultra Sticky has OS 46AX's with 11 x 7 APC props....This plane was resurected from a one month old ultra stick 60 arf kit that was nosed in on its 7 th flight....this is my third year flying it---It always gets a lot of attention when I bring it to the field---3D twin[8D]
Scotte |
:D
I am sure it gets a lot of attention You have one hell of a spear on its nose. :D:D:D |
Recently I the replaced the "spear" with a removable nose---A 9" tip off an old fishing rod/with eyelet on the end....the plane is no longer nicknamed the flying lawn dart:):)
Scotte |
| All times are GMT -8. The time now is 08:29 AM. |
