Control of blimp vectored thrust controls or conventional controls
Should a blimp have vectored thrust controls or conventional controls or both?
Also should a blimp be able to go forward and backward or just forward? |
RE: Control of blimp vectored thrust controls or conventional controls
a blimp has vectored thrust for both forward backward movement and also for descending and ascending tailfin motor makes it change directions
Actually our small indoor blimps are aerostats, not blimps. FS blimps develop significant lift by flying forward, fast enough to make aerodynamic conventional control's effective. Our blimps don't fly that fast. so you must control with vectored thrust on the main fans and a tail rotor.
Here's a link for you to check out... gives a pretty good description of the controls....www.norburnrc.com/whales.htm
| All times are GMT -8. The time now is 07:45 PM. |
