Review: DN Power 2150mAh 25C 3s 11.1v
WA
Here is the review of the DN Power 2150mAh 25C 3s 11.1v
Product link: http://www.all-battery.com/index.asp...OD&ProdID=1984
Price: $53.95 from All-Battery.com
Overall: Excellent battery.
Shipping: USPS. Fast, aprox. 3 business days
Lipo Battery Specifications:
Cells: 3
Voltage: 11.1V
Capacity: 2150mAh
Weight: 5.7oz (162g) – 177g with dean connector
Connectors: dean connector not included, Pre-installed JST balancing connector.
Charge rate: up to 2.15 Amps
Charge temp: 32 to 113 degrees F
Discharge temp: 32 to 140 degrees F
Continuous discharge rate 25C of 43 amps.
Maximum burst of 47 Amps for 5 seconds is ok for every 30 seconds
The battery performs very well under real-world conditions and holds it charge very well.
It at least delivers 27 amps, that is the most powerful motor I have to test it with.
It always get well balanced after charging, around 4.16v each cell.
Storage & Transportation:
1) Store battery at room temperature between 40 and 80 degrees F for best results.
2) Do not expose battery pack to direct sunlight for extended periods.
3) Storing battery at temperatures greater than 170 degrees F for extended periods of time may cause damage to battery and possible fire.
Cells: 3
Voltage: 11.1V
Capacity: 2150mAh
