11.1volt - 1300mAh 25C Li-Poly
WA
Here is the review of the 11.1volt - 1300mAh 25C Li-Poly Lipo Battery Pack
Product link: http://www.all-battery.com/111volt-1...tterypack.aspx
Price: $44.95 from All-Battery.com
Overall: Excellent battery, very light weigth.
Shipping: USPS. Fast, aprox. 3 business days
Lipo Battery Specifications:
Cells: 3
Voltage: 11.1V
Capacity: 1300mAh
Size: 85 x 35 x 18 mm
Weight: 129g / 4.5 oz with dean connector
Discharge (Output) Leads: 15 AWG silicon wire, 85 mm long, No connector
Charging (Balancing) Lead: TP Style 4-pin connector. 24AWG PVC wire, 40 mm Long
Charge rate: up to 1.3 Amps
Charge temp: 32 to 113 degrees F
Discharge temp: 32 to 140 degrees F
Continuous Discharge Rate: 25C / 32A
Burst Discharge Rate: 50C / 65A Maximum burst for 5 seconds is ok for every 30 seconds
The battery performs very well under real-world conditions and holds it charge very well.
It at least delivers 31 amps, that is the most powerful motor I have to test it with.
It always get well balanced after charging, around 4.16v each cell.
Storage & Transportation:
1) Store battery at room temperature between 40 and 80 degrees F for best results.
2) Do not expose battery pack to direct sunlight for extended periods.
3) Storing battery at temperatures greater than 170 degrees F for extended periods of time may cause damage to battery and possible fire.
Photos: (click on the image, for some reason are not being previewed)
Cells: 3
Voltage: 11.1V
Capacity: 1300mAh
