VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
Receiver for VVP set up
Old 12-24-2005 | 10:10 AM
Default Receiver for VVP set up
What Rx are you guys using for indoor flying ? I have a GWS 4channel Rx on another foamy,but it is so glitchy indoors that you can not fly with others in the air. I am considering the FMA M5 or the Berg 4L ?
THANKS,
Rick
Old 12-24-2005 | 10:37 AM
exeter_acres's Avatar
Default RE: Receiver for VVP set up
I like the FMA M5 very much,,,
plus the GWS doesn't have enough channels
Old 12-26-2005 | 03:30 PM
I'm using the Hitec Electron 6 channel. No glitches.
Old 01-04-2006 | 06:30 AM
TooLy's Avatar
I have both gws 4 and 6 channels and esky 6.
Old 01-05-2006 | 11:53 AM
I only use the JR R610ul rx. I've never had any problems. Also Jr makes a new line of rx that will work with Hitec and Futaba and they are good too. There called RS6UL.
Bevo
