VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
Mounting a Variable pitch motor
Old 06-21-2006 | 11:48 AM
Default Mounting a Variable pitch motor
Hi,
Can someone please give me some advice on mounting a Variable pitch motor unit?
I am about to complete my GP Reflection, and need to know how I can mount the HACKER VPS motor system. The problem I have is that the shaft is centred, and would have to travel through the middle of the fuselage. How do I get it past the Carbon rods holding the plane together? Do I need to mount the motor off centre, and if so, wont it affect the built in thrust angle and thrust line, or do i need to bend the rod out directly behind the motor and take it down the side of the plane?
Please help.
Old 10-08-2006 | 07:25 PM
Default RE: Mounting a Variable pitch motor
CHECK THESE OUT THEY SHOULD HELP
http://www.rcuniverse.com/magazine/r...16/mounted.jpg
http://www.rcuniverse.com/magazine/r.../template2.jpg
Old 10-09-2006 | 02:13 AM
Thanks, will do.
Old 10-09-2006 | 07:09 AM
exeter_acres's Avatar
the rod needs to go down the center... get rid of anything in its way....
