VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
mamo models upside down vpp
Old 08-24-2008 | 02:01 PM
Default mamo models upside down vpp
I am working on installing the mamo models vpp system on a park 370 outrunner. Do i need to reverse the shaft on it in order for it to work? Will the 1360kv motor let me reverse the shaft? And if so, how can I go about that?
Old 09-01-2008 | 11:55 PM
Default RE: mamo models upside down vpp
You don't need to reverse the shaft to use the mamo models vpp. Just follow the instrucctions that came with. You can reverse the shaft on your park 370 but you don't have to unles it call for on the plane manual.
Fernando
