Walkera 36 Upgrades
RE: Walkera 36 Upgrades
If you use the [link=http://www.hobbyjapan2000.com/store/proddetail.php?prod=ALUPART3536]Aluminium upgrade parts for the No. 36[/link] ([link=http://www.hobbyjapan2000.com/store/proddetail.php?prod=ALUPART3536]Aluminium Parts Detail[/link]), these parts are much stronger, but they are heavier too. If you use the brushless motor on your No. 36 helicopter, then you can use these aluminium parts.
GA
yes, machined aluminum is stronger then plastic, it'll take a good few more wrecks then most grips would. metal swash, well... unless the bearing's better there's not much of a difference, besides you won't break the balls off as easy (which it usually isn't)
I'll tell you what I find, as I'm getting a CNC upgraded head soon! it's purple... but, I didn't order it. [8D]
