Walkera 5-4 looses lift after 40 seconds....
Hi all Heli Helpers,
My Walkera 5-4 has developed a problem. It acts as though the battery pack is low after about 40 sec. If I let is sit for about 30 sec....actually less....the heli will regain full power and fly for about 40 seconds. Just to loose power and gently come back to the ground. It will do this many times before the battery is actually low. Both my packs will do this at full charge. I cant feel anything getting hot on the 4 in one RX and the motors are not hot. Has anyone experienced this? It seems as though the RX thinks the pack is low or something and decides to reduce the power and will not lift....until I give it 20 to 30 sec rest. Reinitializing the RX has no effect.
Any help will be appreciated.
RE: Walkera 5-4 looses lift after 40 seconds....
hey there i had the same problen with mine after buyiny new batteries and trying another charger someone said it could be the main motor getting tired so i put in a new main motor and it fix it so you could try that hope this helps
