First crash - help!
i just put some thick CA on the piece and glued it back on, hopefully it will stay and I will put it back together in the morning.
EDIT: Anyone know where I can grab heatsinks for cheap?!
two things....
1) make sure to use two nuts or locktite to keep the first nut in place
2) for the sake of balance you should really break off the other side at the same spot and perform the same repair
as far as locating the screws I used the screws the hold the shell on for a computer serial port connector which you might be able to find at radio shack.
about 2-3mm
about 2-3mm
NJ
i broke almost the same part on my first flight. any help please i am very sad [&o] and any tips on hovering a long time
see the ball link under the broken part that what i broke any help
please see this thread http://www.rcuniverse.com/forum/m_4502359/tm.htm and refer to the losi balls for a repair to your ball link
