22e blue head q's
22e blue head q's
hey all got my copter back in one peice after its 1st major crash and its got bad vibes.
ive tryed tracking the main blades and i thing the problem is in the blue head (only part i didnt get).
does your 22e 6ch have a little play in the main blades? i can move mine abit.
cheers
cheers
RE: 22e blue head q's
The head is really quite bad but $99, it's cheap. Mine has a lot of play and I know how to tune these birds.
I've kind of given up on the 22E and the blue head is too expensive considering a bare bones 36 is $68. It's fine for kicking around but seriously, you can get [link=http://www.tedani.com/sjm-400-3d-without-motor-p-905.html]a sjm full cnc heli[/link] for about the same price as the cnc head and I have all the electronics spare to run it.
The screw in your head may be loose. The blue head should not be able to slide up and down on the shaft. Also make sure the brass knurled nut is tight.
I don't think I understand. Do you mean you can twist the blades, or the blue block rocks from side to side, or what? I'd say I get very little head movement, and that's how it should be. If I try to rock the head/blades up and down, there's no movement. If I try to twist the blades (one towards me, one away from me) I get a little movement. I would think the less the better, but I don't think you can eliminate all of the slop. If I try to lift straight up on the head while holding the heli down, I get no movement.
Can you elaborate on your problem or post pictures?
-JT
-JT
its fixed now, the blue head had lots of slop witch i got rid off but the problem was still there.
changed the blades and the vibes where gone.
new problem doesnt lift ;( till nearly full throttle.
I'm done. I can't seem to learn how to fly this thing.
I have three of them on sale at eBay, NO RESERVE on any of them.
Non working one, only good for parts : http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EF:US:11
Working condition: http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EF:US:11
Modified + Upgraded w/ CNC Head + Brushless Motor + Speed Controller cost me over $350: http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EF:US:11
Good Luck.
Good Luck.
