2Ch. Transmitters on Helis
Does anyone know if it possible to use a different Transmitter with a 2ch. Dragonfly Heli, mine like most is on 27.145mhz but I don't know if it is FM or AM and I would like to use my Futaba Attack SR 2ch. Transmitter with it. Also does anyony know if there are any upgrades available for these 2ch. helis?
RE: 2Ch. Transmitters on Helis
Which heli do you have? (maker,name) Most of the little helis are AM, if you could replace the RX your radio might mork in there. I can tell you how to do it but need more info on your heli and if you have the RX for the Futaba.
That has the speed control and left and right with the tail rotor right? So it basicly has two speed controlers on a RX board inside. All the parts are on one board and not seperate so it would be imposible to fly it with a differnt RX.
