4g3 brushless tial motor decent or crap?
VA
I was just over on wowhobbies and there are two different tail motor packages, one made made by Walkera 2g(bushings) and another turbo ace thats 2.9g (bb), they say the 2g can not take take a crash and that you should pick up there other version(30.00 more) because it,s tougher is it a marketing sceme? because it also states that the walkera main motor brushless upgrade will not keep up with this tail and you also nee the turbo ace main motor, so has anyone had any trouble with the walkera brushless tail is it ok for the price, or is it crap pouring out on the net to make an extra buck or is it really just garbage?
RE: 4g3 brushless tial motor decent or crap?
No its not a scam the 2.9g is a better motor than the 2.0g (1.9g) it will last longer and it uses a different mount so if you do buy the 2.0g version and later upgrade to the 2.9 it will cost you more, I think the mount is $20 on its own + cost of motor.
ORIGINAL: joeyhatch11
I was told the stock BL motor can pop out/break off in a light crash. The 2.9g upgrade solves that problem.
And you should check out the motor holder made by jjetski, I think clubheli sells them. the wow ones break easily
