Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
Slow rotation in hover
Old 01-22-2010 | 06:17 AM
Default Slow rotation in hover
<p class="MsoNormal" style="margin: 0mm 0mm 10pt"><font face="Calibri">I would really appreciate some feedback. I have a CB 100 (which I would recommend to any flyer who is upgrading from a coax). This little machine is very stable in a hover &ndash; except for one problem; it slowly rotates in an anti clockwise direction within a half to one meter radius, without any nose-drift.</font></p><p class="MsoNormal" style="margin: 0mm 0mm 10pt"><font face="Calibri">My CB 100 has taken a good few nocks, but there is no unusual vibration or external damage.</font></p><p class="MsoNormal" style="margin: 0mm 0mm 10pt"><font face="Calibri">I hope that you can give me some suggestions to remedy this problem, as I&rsquo;m having difficulty controlling my heli in my lounge &ndash; which is big enough to cause a battery hen to feel claustrophobic!</font></p>
Old 01-22-2010 | 12:53 PM
Default RE: Slow rotation in hover
I had asimilarproblem with the 4g6.
I changed the pitch and it seemed to go away. PIT from 0 to -71....PIT REV and PIT to 71%.
One time, I also has one of the tail rotors loss and not spinning....ones fixed Ididn'thave this problem anymore.<br type="_moz" />
Old 01-22-2010 | 01:04 PM
take your flybar off and make sure it is perfectly straight (roll it on a flat surface) if it is bent then that is the cause of your rotation aka TBE (toilet bowl effect)
Old 01-23-2010 | 09:38 AM
Thanks a lot for your advice which has been a big help. Although the fly bar looked ok at a glance, it was slightly bent when removed and examined - after straightening it out the rotational problem disappeared.</p>
Many thanks to GenkDesu and AtTheCross for your help.</p>
Old 01-23-2010 | 10:46 AM
good deal glad you found it
