LAV-25
There's a 1;16 RC LAV-25 on EchoBayvious with water cannon supoosed to shoot a pretty good distance. Any one familiar with this model?[&:]....who makes it, replacement parts available....compatable with HL-Tam?? I'm intetrested in only the water gun to mount in my Sherman where I have installed a flame gun. (OK, only water [:@][>:]
]) Once I have it, I have no use for the LAV unless I can convert it to a German 8 wheeler. Would appreciate any info.
Bill
]) Once I have it, I have no use for the LAV unless I can convert it to a German 8 wheeler. Would appreciate any info.Bill
MB, CANADA
Bill-Does it look like this?
[link=http://www.matotoys.com/canada/product_info.php?cPath=23&products_id=179]Water-Squirting LAV[/link]
I was thinking of getting one of those myself just to mess around with....
Paul McD.
Paul McD.
SK, CANADA
I have 2 of them. 1 works and 1 is parts. lol what is wrong with them..
1 - Only rear wheels drive.
2 - not a 'locked diff' so 1 wheels can steer
3 - wheels are hard plastic
4 - only front wheels spin
5 - cannon level has to be moved by hand. not rc
6 - controller is very cheap.
now if someone took one, gutted the reservoir out of it, re-made the axles, put chain drive on the inside and used some gear boxes and made it like a tank that would rock.
also flashing 'cop' lights on it get annoying.
edit: the pump is actually good. its a 3 roller style and has lots of punch.
yep, that's it.....only interested in the water cannon system for a flame thrower mock-up. Think it would be piossible to mount in the Tamiya Sherman? Thanks for the info...I'll check the others out too.
Bill
Bill
SK, CANADA
umm... dose not look anything like a puma man. front axle steers, middle 2 are not full axles, and rear is only drive. also wheels bad.
this is what a puma should look like:
[link=http://s15.photobucket.com/albums/a379/ANTheStuff/RC/Puma/?action=view¤t=puma.flv]
[/link]
[/link]
MB, CANADA
Did I start something or what....? I was planning on just turning the turret around --ie, making the back into the front. I don't even care if it "turns" all that well. Just wanted some "easy meat" for my Sherman
