Armor Comparisons
Think the Maus had thick armor?
Here is an interesting list of relative protection based on effective armor protection (as if millimeters of hardened steel plate).
Protection:
M1- 400 vs KE 600 vs HEAT
M1A1- 450 vs KE 700 vs HEAT
M1A1HA- 600 vs KE 1150 vs HEAT
Leopard 2A4 - 700 vs KE 1000 vs HEAT
M1A2- 760 vs KE 1400 vs HEAT
Lacrec- 800 vs KE 1600 vs HEAT
M1A2SEP- 840 vs KE 1400 vs HEAT
Leopard 2A5- 870 vs KE 1500 vs HEAT
Challanger 2- 960 vs KE 1700 vs HEAT
Leo 2A6 may be as high as 1000mm vs KE.
T-72B - 530 vs KE 620 vs HEAT
T-72BV- 580 vs KE 1120 vs HEAT
T-80B- 550 vs KE 650 vs HEAT
T-80BV- 600 vs KE 1150 vs HEAT
T-72BM- 780 vs KE 1220 vs HEAT
T-80U- 820 vs KE 1350 vs HEAT
T-90- 1000 vs KE 1600 vs HEAT
Really amazing how much technology has improved protection and this is ONLY the passive portion!
Protection:
I'm always leery when a book or a website post that kind of info...because those are supposed to be classified. Makes you wonder whether they're just guessing, or have someone on the inside. And I suspect some of those numbers are simply Russian and European arms contractor guesstimates, which tends to inflate numbers in order to wow potential buyers.
The tank is often used as a "bully" these days, the likelihood of tank on tank combat is less likely than it used to be. The non- technically equipped opponent is going to battle in a different, more urban fashion.
That will demand a different approach to how tanks are deployed in future. If they remain in the arsenal in the current format, on a large scale.
ORIGINAL: Chally2
ORIGINAL: Panther F
I agree, but some countries need to be careful they're not taking a knife to gun fight. Imagine T-72's crossing the border only to find M1A1's and Challenger's to greet them.
ORIGINAL: Chally2
That's true but the T72 is still a very capable weapon if properly deployed and should never be underestimated. We still need to be on the ball and not rely on technology to protect us.
Armour protection should be likened to a goalkeeper, the last resort for a broken strategy. Many cases of tanks being disabled is down to improper use and deployment of infantry support (because commanders are scared of the political ramification of putting infantry soldiers in harms way). There are other causes of tank losses of course, some down to poor tactics in other areas.
I'm beginning to sound like a broken clock here, sorry about that mate.
I should get out more often.
Or just shut up.
Banned
problem is stan your right mate as they've witnessed in afghan and Iraq A lone "Terry" with an R.P.G can do a lot of trouble
as long as he get's it right[X(][X(][X(]
]as long as he get's it right[X(][X(][X(]
It is a well known fact the M1A1/2 can be KO'd by 25mm rounds (in the rear), so yes deployment strategy is key. Tanks are vulnerable when not utilized properly.
A RPG can be every bit as dangerous as a MBT.
ORIGINAL: heavyaslead
ORIGINAL: Panther F
It is a well known fact that all tanks are vulnerable (in the rear) by another tank or RPG. I was just using the M1A1 as an example against the much inferior T-72 as was proven once before.
If you guys want to know just how vulnerable Russian MBTs are, especially T-72s and T-80s, read how easy they got knocked out by Chechen infantry. Even the side turret armor is vulnerable to RPG hits. Especially during the numerous battles for Grozny, Russian armor were routinely destroyed by infantry not only because of poor tactics, but also just plain bad design.
Not enough machine guns, the main gun cannot elevate or depressed enough to engage Chechen fighters in buildings, or in basements, and thin side armor (even the side turret armor).
Not with active defense, like Trophy, its all around protection.
ORIGINAL: Panther F
So I remain correct that the fact all tanks are vulnerable (in the rear) by another tank or RPG.
Well, my interpretation, Panther F, is that if the initial attack can be thwarted, that at least gives you a chance to counter, thus considered protected I believe, if even once.
The Russian Thrush2 is multi-axis and has multiple firings.
We both agree tanks are vulnerable, however active defense can supress the 'surprise' element.
Well heavyaslead, I've never heard of a single RPG attack on a tank before. But I guess it's possible.
My interpretation of all around protection is permanent protection. Not just one use.
Why argueing? Tanks are not that important now as they were 65 years ago. Aircrafts rule! The one who owns the air has 50% of victory in his pocket. The end of WWII showed this very clearly when carpet bombings made it almost impossible for Germany to wage war.
ORIGINAL: EugeniRUS
ORIGINAL: EugeniRUS
Unfortunately aircraft cannot move onto and consolodate a strategic position. This is why we still have tanks and mechanized infantry.
ORIGINAL: Panther F
Arguing? Is that what we were doing?
Just joking, of course.
Almost.
ORIGINAL: Chally2
How could anyone consider you argumentative, I ask myself (without doing a recent forum search[X(]).
Almost.
ORIGINAL: Panther F
Almost.
Not joking, of course.
Remember the old Cold War / NATO joke?
A Russian general met another in Paris after having swept aside the initial NATO resistance and marched into the Fulda gap. One asked the other, "By the way, Comrade, who won the air war?"
ORIGINAL: EugeniRUS
America in Vietnam
Russia in Afghanistan
RPG's are being used against tanks in Afghanistan and Iraq on a daily basis hence the need for "Bar armour" modern tank armour was designed to defeat modern anti tank rounds (Darts) they struggle with hollow charges such as RPG, unfortunately Sindbad and his mate have a lot of these weapons
ORIGINAL: mackem
If everything could be done from the air then I'm quite sure the powers that be would do things that way.
ORIGINAL: EugeniRUS
The Armour vs. Gun race is ongoing but I believe the Gun is winning. Until new type of light and very strong armour is invented. The top is reached. Abrams and the like are on the top. They are already very heavy and eat a lot of petrol. For now I see no way for an absolutely new tank to appear.
