War Room Discuss historical, battles, battle grounds, events, combat strategies and more right here!
CombatSeries
Old 01-12-2009 | 03:54 PM
Default CombatSeries
Dear Guys
I’m interested to build on table polygon to use micro RC tank (1/48 or 1/54) with IR combat system
I did some internet investigation and than I bought VS Tank-R.
And I’m disappointed. This is no possible to steer this tanks precisely. There is no proportional or even quasi proportional steering. If you make turn, tank start to rotate and it is impossible to make it precisely.
IR combat system is OK but this steering.
Also tank can run only about 3-5 minutes after charging.
So my question is:
Do you guys know any other RC tank with similar scale with combat system with proportional or semi proportional steering. Just to steer precisely enough to go through labyrinth or in direction you intend.
I have found KONAMI Micro IR or Hobby Master 1/48 CombatSeries
Do you know will it suit me?
Do you have any other ideas?
Waiting for answer
Jaro-Poland
Old 01-12-2009 | 10:39 PM
ArmChairGeneral's Avatar
Default RE: CombatSeries
I think to move accurately you need a bigger scale, I have found 1/16 to be best in cost, realism and reliability.
Paul
Old 01-13-2009 | 03:35 AM
swathdiver's Avatar
I think the scale is too small to get good equipment and a cost effective battery into. The topic should be in the main room, not up here in the war room.
