Weatronic Support Forum Go here to get help with your Weatronic products.
MC22 switch adapter
Old 03-07-2012 | 12:03 AM
Default MC22 switch adapter
Hi everyone
Ihave been converting to 2.4GHz gradually by buying Weatronic Rxs. I still have quite a few 35MHz Rxs so swap over the leads in my Tx to either internal 35 MHz ot Weatronics module. Weatronics do a changeover switch (WEA 37735) that should make this change just a switch flick. The description on the website does not make this clear and e-mails to Weatronics have gone (surprise surprise) unanswered.
Has anyone used this switch and does it work as I assume it will, I don't want to spend 49 Euros and find it does not do what I want.
Thanks in advance.
Norman
Old 03-07-2012 | 05:21 AM
Pelle Gris's Avatar
Default RE: MC22 switch adapter
Hi Norman.
I also use an MC-22 with Weatronic module, but I skipped all my 35MHz gear, so I have no experience with the switch module.
But, I have had good luck with calling Weatronic when I have had some questions. The guy I got on the phone last time spoke english just fine, although you have to live with the ´Allo ´Allo! style dialect... :-)
Old 03-22-2012 | 05:57 AM
Thanks for the information, I went ahead and bought one. It does work asI imagined. I have mounted the Tx module to the right of the 35MHz socket and can now change between 35 MHz and 2.4 GHz using the locking switch, no need to open the back and relocate the plug.
Good if you still fly with some 35 MHz but expensive for a switch and some sockets at 48 Euro......
Norman
