Slave/sub receiver with DV4 transmitter module?
Hello!
What are your experiences of the use of slave/sub receiver with DV4 transmitter module? I use Weatronic in my Mpx Royal Pro 16. Talked to Weatronic today and they said that one should be "aware" to have important functions rudder when using my intended setup. I will double post this in the RC Jets forum as well.
/Ville
/Ville
Works, but put important functions on the primary RX. In the BAT6x TX you can have two slaves instead of one and they also send basic telemetry data back to the TX. This is possible due to a change in the RF Link protocol. The (up to 3) RX are not connected via cable, so their placement is principly independend. But I would also put the most important functions on the master if possible.
Regards
Thomas
Regards
Thomas
