Red switch board led flash frequency
Hi, this is a great forum for Weatronic users.
Is there a logic regarding the red switch board LED flashing frequency?
I have noted that this frequency is not constant either on one flash ( bat 1 ) or 2 flashes ( bat 2 ).
Does this mean something ?
Thanks.
Oli.
Thanks.
Oli.
My Feedback: (8)
FL
That is correct. This frequency tells you which is the Battery pack in use. This indicator can be seen from the air. This was designed to let you know that you are using your backup Battery.
Tony Fandino
Tony Fandino
Well the question is not about the number of flashes, but the frequency at which these flashes occur.
Sometime the blinking is slow, sometimes it is fast.
What is the logic behind ?
OR
Hi Olnico,
The LED flashes at 1 Hz (slow) when it is using battery one. It flashes with 2 Hz (twice as fast) when battery 2 is in use.
Gerhard
Gerhard
OK. I had the feeling that this frequency was not fixed and function of the battery charging level. I must stop drinking and building then...
