35% Giles...
My Feedback: (508)
I bought a 35% Wild Hare Giles from a friend... it has a BEASTY ZDZ 80 single on it with pretty good Hitec servos...
The problem I have with the plane is on landing... it seems to bounce... ?? !! Two feet off the ground ... I ease it down... and it bounces...? into the air and wants to fly again... I have to keep some speed on it on landing as if it gets too slow... it tip stalls...!!
Any suggestions or tips... ??? I sure could use them...
Larry
Larry
TX
Are you sure it's a WH G202? Neither the bouncing nor tip stalls are part of the normal behavior.
When I land mine I normally just let it glide in at idle. Let it descend on its own, if it seems like it wants to float it might be a touch tail heavy. It should establish a pretty good glide slope on its own.
At about 10 feet I put in a touch of up elevator to flatten it out, then let it come down to about 1 foot high and feed in elevator to hold that altitude, when it quits flying it should just set down on the gear.
Your description sound like it would benefit from a more forward CG. The ZDZ80 is very light which makes it harder to get the proper CG.
TF
TF
Banned
ORIGINAL: les2097
Larry
Larry
My Feedback: (508)
Thanks for the info guys... this plane does not float...!!! I think the CG may be too far forward... although it is nicely aerobatic...
This bouncing is the pitts...!!!
I was running a Bambula 24x10 on the ZDZ 80 ... Whacha think about a 24x8 ... maybe slow it down some although the landing speed is not real fast...
Marc... I liked your plane so much that I finally found one with a trade that I could afford... but landing is not good....
Where do you guys have your planes balanced???
Larry
Larry
Banned
Larry - my plane was balanced where you set it. I had the BME 102 on the nose. 26x10 CF prop. I think the CG was where the manual recommended it if I recall correctly.
Are you landing on pavement or grass?
Any and all information you guys are willing to share regarding the G-202 would be noted with the utmost welcome. I have one that I am going to be starting on soon, and things are always easier if you become educated about habits prior to the first flights.
Pat
Pat
TX
The G202 flies and lands well with the CG about 1/2" to 3/4" in front of the front edge of the wing tube. The manual used to say 1.5" to 2" forward, that was very conservative and difficult to achieve with any engine lighter than a briggs and stratton. I changed it because yje general consensus was that was too conservative.
IF your balance point is no more than 1/2" ahead of the wing tube the plane should just settle in gracefully and set down without bouncing. Maybe try some low bounce tires?
TF
TF
Guys I have been flying one for a while. I have the BME 102 in it. I balanced according to Tom's suggestion of 1/2 o 3/4 inch in front of the wing tube. At this point the plane floats in as gracefully as does my 35% WH extra. I fly at a field where landing North to South is very tight on final due to trees.
Eddie Bernaldez
Eddie Bernaldez
WI
My wild hare g-202 was a little tricky to land untill I got the idle as slow as poss. I'm running a zdz 80 and mejzlik 26-10 and that combo is flat out amazing,I think that prop still really moves alot of air and anything above a very slow idle it just keeps flying.Ive got about 150 flights on mine so far and i'm more impressed every time I fly it! none of the so called nasty g202, tendencies just a great flying aircraft!Great company to deal with also![8D]
