Edge 540 Rudder tiller
AZ
Does any one know what bolts that you use for the tiller bar and tail wheel bar?. I have the parts kit from Wild Hare and there is 2 long bolts left over from the Rocket City pack for the ailerons and elevators, are those the ones that you uses or is the black bolts that come with the Duo Bro pack the ones that you uses.
RE: Edge 540 Rudder tiller
In almost every case, you will have hardware left over from a Rocket City linkage package.
There should be a very long 8-32 screw that you will thread through the hole(s) in the rudder after you drill out and tap the pilot hole(s). After you thread the screw through the rudder, and making sure that you have equal lengths on both sides, cut off the head of the screw with a Dremel tool, or equal, cut off wheel and clean up the threads at the cut end. The "horns" screw onto the remaining shaft on both sides of the rudder.
AZ
Thanks Tom I got it all hook up and it is working fine. My new Edge is just GREAT but I was some what disappointed in the canopy. It had a lot of scratches on it . The protective covering must of come off in shipping.
