WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Servo connector keepers
Old 03-26-2005 | 01:29 AM
Default Servo connector keepers
Where can I find more of those servo connector keepers that WildHare has in their hardware packs? You know the white plastic zig-zag things?
Alan
Old 03-26-2005 | 01:58 AM
Default RE: Servo connector keepers
Tom decided a long time ago that they were to be called "squiggles". He has them.
Old 03-26-2005 | 10:29 AM
OK, so Tom how much for some Squiggles?
Old 03-26-2005 | 10:44 AM
3dd's Avatar
3dd
check slimline,they have a neat keeper
Old 03-26-2005 | 11:22 AM
Tom's are a lot cheaper. I think I spent thousands for them when I ordered some extra from him.
Somewhere around the couple of dollars for ten or twenty, but it's been awhile now.
Old 03-26-2005 | 04:48 PM
Banned
It sounds as if you are going to use these on all your extensions? If you are I would strongly suggest that the ones that stay hooked up all the time that you should use shrink tubing (cheap and easy won't come off or get snagged on anything) the so called "squiggles" should only be used on aileron connections and what ever else you disconnect every time you put the plane away.
Old 03-26-2005 | 05:21 PM
rctom's Avatar
I tend to agree, the squiggles (we get them from Tetherite plastics) are really meant for things that are not permanent, heat shring is cheaper and more secure.
TF
