WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Rudder Pull Pull
Old 07-24-2005 | 08:19 PM
My Feedback: (37)
Default Rudder Pull Pull
Guys,
My Rudder cabels are hitting my Elevator servo arms (Airwild). Actually I should say that my Elevator servo arms are hitting my rudder Pull Pull cable. Should I extend the Pull Pull exit holes? or what? Here is my set up.
Bruce
Old 07-24-2005 | 08:25 PM
My Feedback: (37)
Default RE: Rudder Pull Pull
One more. It hits when the elevator is at 30%+.
Old 07-24-2005 | 09:06 PM
charrua's Avatar
My Feedback: (47)
I'm not sure on the extra but the edge the elev. servos were moved farther foreward and up a bit and there were some other holes that should be used to install the rudder servos in the tail if you needed to.
Maybe you installed the elev. servo in the rudder opening!!! Don't you have another opening on each side a bit higher!!! here a pic on my edge!!!
See if you look at the pic. you can see the other hole for rudder servos,, it's just below the pushrod and s bit to the left!!!
Old 07-24-2005 | 10:20 PM
My Feedback: (37)
Mine is an older version. I don't have the upper servo mount. I think I got it figured out. This is my first gasser so I want to make sure all is right before I finalize something.
Thanks for your help though.
Bruce
Old 07-24-2005 | 11:41 PM
On my first Edge, which was an early edition, I used a SWB 1" arm
going up, instead of down. worked great and everything cleared away
from each other. give it a try.
Gerald
Old 07-24-2005 | 11:52 PM
My Feedback: (37)
I actually tried the Airwild 1" Didn't give me as much throw as the 1.25. I got everything set up now and it all clears by about 1mm. I may cut my bolts back about 2mm and then I will be even better.
Thanks for the advice though.
Bruce
Old 07-25-2005 | 05:39 PM
bluemagic98's Avatar
My edge has the servos in the same spot and my cables go behind the arm the same way I used a 3" arm on the rudder servo and crossed the cables in the fuse. I have the rudder end at 3" as well and it clears everything. when i look at the pic Im asking myself just how far appart are the cables at the rudder end on your plane?
Old 07-25-2005 | 08:56 PM
DENNIS C's Avatar
My Feedback: (99)
On my edge i had my servo arms 1 1/4 " pointing towards the surface. they were close to the stab but they cleared
Old 07-26-2005 | 09:48 PM
My rudder cables are rubbing on the woood on the inside of the fuselage. I did not cross the cables. Should they be crossed or are they ok as is?
Old 07-26-2005 | 10:27 PM
rctom's Avatar
If you mean they are rubbing against the fuse side, that is OK but if you want to cut away a little wood to clear it won't hurt either.
Tf
