WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
WildHare 540 Edge weights??
Old 09-22-2005 | 01:44 PM
Greg Cothern's Avatar
My Feedback: (8)
Default WildHare 540 Edge weights??
What weights for your setup are you getting with the Wild Hare Edge 540? I have one with a ZDZ 60, wrap around muffler, Li-ion batteries, etc and weighing in at a heavy 18lbs 10 oz's. This weigh down with battery replacement to Ion versus 10 cells of NiMh (sub C) that weighed in at 13 oz's more than she does now with the Ions. Weighed on a digital scale supposedly accurate to with 1/2 oz.
I would love to get close to 17 lbs even, I could swap to a ZDZ 50 and loose almost 3/4 of a lb but dont think it would perform as well power wise as it does now?
I am running all stock hardware, stock aluminum tubes, landing gear, and etc.
Thanks in advance.
Old 09-22-2005 | 01:52 PM
bluemagic98's Avatar
Default RE: WildHare 540 Edge weights??
mine has the DA 50 and 2 2400mah li-ion's on the rx and 1 1200 nmh on the ign all stock hardware and im at 18lbs
Old 09-22-2005 | 05:03 PM
Dugster's Avatar
16 lb. 4oz. [8D] DA 50 w/ slimline pitts, single 2200Mah lipo on Rx, 1500 lipo on ignition, CF wing tube, stab tube and tail wheel, foam main wheels, all other gear stock. Flies great! Very unlimited vertical!
Old 09-22-2005 | 05:19 PM
mstroh3961's Avatar
DA-50 slimline pits, CF wing and stab tubes tail wheel, WH FG gear, Kavane wheels, 3- 1650 NiMH packs. 16.75 LBS with unlimited vertical!
Old 09-22-2005 | 05:28 PM
My Feedback: (8)
So here is a question then, if I changed to a ZDZ 50, CF gear, CF tube, etc and get the weight down to say even 17lb would the 50 have unlimited vertical performance?
Old 09-22-2005 | 05:32 PM
charrua's Avatar
My Feedback: (47)
mine with DA-50 2 2400 li-ions and stock everything first flight weighted at 18lb 8oz and it had unlimited vertical,,,
since I have upgraded to CF Wing tube, Stab Tube, Tail Wheel, Kavan main wheels, and CF Spinner and changed from 24oz fuel tank to a 16oz and I saved 2+ oz on the empty fuel tank alone,, Stock Aluminum LG now I'm at 17lb .
a full 24oz tank weight 1 1/2lb and I think the 16oz one is like about 1lb.
Don't change the motor change upgrade to CF everywhere but the LG Stick with aluminum!!!!!
Old 09-22-2005 | 05:41 PM
My Feedback: (8)
Well I can use the ZDZ 60 on another plane I have needing an engine is one reason why I was thinking of the change, not too mention if I changed to the 50 would loose 3/4 lb. Balance would be easier with changing out to all CF tube, gear, tail wheel, etc.
At this moment I have the batts on the CG basically, with rudder servos in the tail.
Just trying to make it fly lighter on the wing, I have a H9 33% Cap that weighs 24 1/2+ lbs and flys extremely light, matter of fact if ya dont get her slowed she wont land on our field just float by, LoL.
Old 09-22-2005 | 10:17 PM
scottfl78's Avatar
Mine is all stock with DA-50 and 2000mah 6v NIHMS for the Rx and Ign, 17 lbs.. Sems to fly nice/light..
Old 09-24-2005 | 06:28 AM
Cobra1's Avatar
My Feedback: (42)
16 lbs 2 oz.....I have weighed mine twice to be certain. Da50 w slimline muffler, light aluminum WT, light aluminum gear, JR8611 on rudder, HT5945 on all other sufaces, standard servos on throttle and choke. 4.8v 1650mah for engine and 6v 2100mah for radio. I don't fly alot of 3d so my batteries give me an hour of good flying. The lighter tube and gear saved almost a pound!!
Old 09-24-2005 | 07:00 AM
My Feedback: (7)
Brison 3.2, two 2400 Li Ions,1600 maH Nimh on Ign,modified LG, CF- Tube, Kavan Wheels from TBM, weighing in at 17.2 lbs. Unlimited vertical.
Old 09-24-2005 | 11:54 PM
DiscoWings's Avatar
My Feedback: (76)
My Friend has you all beat, just waiting for these damn hurricans (katrina & rita) to go away to maiden. Engine runs super strong! 6800 rpm with 22x10 prop on ground! AND THE DRY WEIGHT"
15LBS & 4 OZ!!
CF: wing tube, stab tube, tail wheel, gear
CF: Pushrods
Titanium: Control Horns
Hs-6895 Coreless karbonite all control serfaces (they say 4x as strong as nylon, I think I'll be ok, a guy uses these on a 33% and he does ok), Hs-5995 pull-pull rudder
Hs-81 Micro: Throttle
Choke: no servo
Engine: Evo 45 mag w/Inverted modified DA-50 pitts
2200 lion w/mircalse siwth
1500 lion NO REG! moded ignition to work on 7.2 volts!
Foam Wheels
Should be a rocket and light as feather!
Old 09-27-2005 | 03:00 AM
The 28% Edge will fly great at weights from 15 plus to 21 pounds. Don't be too concerned with what you come up with, just enjoy.
Old 09-27-2005 | 08:37 AM
rctom's Avatar
Greg:
Isn't that the Edge that you crashed and rebuilt?
Glue adds an incredible amount of weight.
TF
Old 09-27-2005 | 04:52 PM
My Feedback: (8)
Tom it indeed is however the original weight before maiden was almost 19 1/2 lbs. I am curious as to what bird the ZDZ 60 was actually designed to work with hehehehehe. Seems it is slightly on the heavy side for most of the 27-29% birds and underpowered for anything bigger LoL.
I am thinking of selling the 60 to buy a new 50cc engine for this thing! Wish it had enough power to fly the Giles or the 260 but alas would not come close to doing justice on either bird as I think they would be closer match for this engine, in my opinion that is.
Old 10-11-2005 | 12:38 AM
I'm flying the edge with the ZDZ 60 and my weight is 18 pds and I get unlimited vertical. I can torque at about a third of throttle. I'm using a 24x8 BME prop and I couldn't ask for a better engine/ plane combo, the ZDZ is just stuborn cranking when cold unlike a DA. I really like my ZDZ and Wild Hare so don't be discouraged, just go fly it and you may be surprised. Wing rock is my only regret and I intend on moving the CG from 4.75" to 5.25" to see if the problem goes away.
Old 11-05-2005 | 03:55 AM
My Feedback: (7)
I've got the Edge, also with the ZDZ-60RV, Super Sonic Pitts, 24-8 MCS prop, fiberglass gear, CF wing tube, two 6v NiMh 1650mah for RX, one 4.8v NiMh 1200mah for Ign., No wheel pants, CF tail gear, pilot, panel, and the rest is the stock gear from the hardware kit.
AUW . . . 18 Lbs 8 oz.
Old 11-07-2005 | 01:52 AM
All stock Edge,Da-50,bisson power wrap around,two 1650 NIMH batteries for ignition and reciever.Its close to 17lbs.
Old 11-07-2005 | 02:00 AM
ben beyer's Avatar
My Feedback: (23)
ORIGINAL: charrua
So, I shouldn't upgrade to CF landing gear? I was going to change everything out since i'm using an Evolution 58 and i'm at 5000 ft.
Old 11-07-2005 | 08:32 AM
My Feedback: (7)
Ben the CF gear tends to de-laminate.
The better choice is to use Toms FG gear if you can get it.
Old 11-07-2005 | 10:03 AM
ben beyer's Avatar
My Feedback: (23)
Hmm, he no longer carries it. Guess I'll just have to use the aluminum. I'm going to be putting an Evolution 58 in it so I should be ok with the extra 7 oz.
Old 04-18-2006 | 08:04 PM
marzo91's Avatar
My Feedback: (57)
Mine has a Taurus 3.2, no choke servo, no pants, no spinner, CF wing tube, Kavaan wheels, and no pilot. It weighs 16 pounds even. She stripped a bit, but that's o.k.
