WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Fitting a Canister in 28% Edge
Old 11-07-2005 | 06:44 PM
ben beyer's Avatar
My Feedback: (23)
Default Fitting a Canister in 28% Edge
I would like to use a canister muffler in my 28% Edge that I'm getting that will have an Evolution 58. Is there anyway I can do this and still mount the fuel tank under the wing tube? Someone mentioned a way to "lift" the tank tray to get it to fit.
Old 11-07-2005 | 08:07 PM
My Feedback: (31)
Default RE: Fitting a Canister in 28% Edge
on board
Old 11-07-2005 | 09:56 PM
ben beyer's Avatar
My Feedback: (23)
So, I guess I need to ask Tom about this. He sells the muffler i'm buying plus he could tell me the difference between the "power" Bisson muffler and using a canister. So Tom is there a difference between a canister for the EVO 58 and the "power" Bisson muffler?
Old 11-08-2005 | 12:27 AM
rctom's Avatar
They are completely different, I don't really understand the question.
TF
Old 11-08-2005 | 12:41 AM
ben beyer's Avatar
My Feedback: (23)
Sure, is there a big difference in the power the engine puts out between a canister muffler and the power Bisson muffler you sell for the MVVS/EVO 58
Old 11-08-2005 | 08:26 AM
rctom's Avatar
There should not be a big difference, but I have not yet tested it.
Here is the situation.
I tested the MVVS/Evo 58 first with a Slimline muffler modified from one for a DA50. That one did 6800 rpm with a 24-10 Mezjlik prop. This muffler has 7/8" OD outlet pipes.
I then retested it with a header/canister setup. I expected great things, but was disappointed to see that it was exactly the same 6800 rpm.
I have run the same engine on our newest Bisson quiet muffler with 5/8" outlets but have not measured it with a tach. IT seems to be down on power from the canister/slimline which is expected by my observation, I'd guess it's in the 6300-6400 RPM range now.
I also now have a Bisson muffler with 7/8" outlets but have not tested it yet. I am expoecting it to be similar to the slimline/canister setups.
Remember that with the Bissons they crimp the tips of the outlet pipes down to a very small hole for noise reduction. You can always cut off the tips to decrease backpressure which in most cases will increase power.
TF
Old 11-08-2005 | 09:38 AM
ben beyer's Avatar
My Feedback: (23)
Ok. Sounds like the power Bisson will probably be about equal to the canister since it has 7/8" outlets. Should be open enough to allow the engine to breathe.
