Here is the Instalation of Canister in Extra 300 LX
My Feedback: (76)
Plane: Extra 300 LX
Engine: EVOLUTION 58 GX
Header: Custom Made KS parts
Canister: MTW 75k
Mount: MTW mount
Air Tunnel and cage: 1/64th inch plywood.
Canister: MTW 75k
Mount: MTW mount
TX
RE: Here is the Instalation of Canister in Extra 300 LX
I would worry about what will happen when you open the throttle to start yor takeoff run. With the gear thatfar back it may try to mose over.
Also you have the muffler mount way back at the back of the canister. If you would refer to the writeup I did in the downloads section of the Wild Hare web site the mount supports the canister in the middle, which meeks G-loads from stressing the header. Also that way it's mounted on the gear plate and not on a stringer.
Other than that it looks very good.
Tf
Tf
