wh edge 540
there used to be a web site edge 540t.com,lots of info and pics on the build and set up of this plane,it seems not to be running any more,do we have another site on build and set up with pics on this plane
The 300S is almost the same plane as the Edge with the exception of the wing panels. Anything that applies to the Extra also applies to the Edge. You won't go wrong using the Extra threads for information and direction. Keep in mind that the Edge cannot balance as far aft as the Extra due to the difference in the wing planform, but it always seems that the placement of the various components comes out the sme with each plane.
My Feedback: (47)
GA
ORIGINAL: kingtight
Here is when I started working on mine and deciding which one to get if the Edge or the Extra!!! I posted a lot of pictures and some other guys too this might help!!!!
http://www.rcuniverse.com/forum/m_24...2CExtra/tm.htm
