WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
WH edge engine trouble
Old 04-07-2006 | 09:07 PM
Default WH edge engine trouble
Today when starting my edge with a da-50 the motor stuttered immediately after starting,but cleared right up then ran fine in the air,ofcourse it still making that popping sound,when i flew again it did the same thing,also i have to use my choke almost all the time to start the engine,what am i doing wrong??
Old 04-07-2006 | 10:01 PM
ben beyer's Avatar
My Feedback: (23)
Default RE: WH edge engine trouble
Sounds like it's lean on the low end.
Old 04-07-2006 | 11:55 PM
Makes sense,i recently leaned the low end a little,but it runs great in the air,and revs great on the ground,just gets a little hesitation at first starting,ive been told alot of the da's make that gurgaling sound in the air sometimes.Other then that,the motor sounds and runs great.
Old 04-07-2006 | 11:56 PM
I did not mention that its always been a ***** sometimes to start,even before leaning the engine.
Old 04-08-2006 | 04:29 AM
Idle trim full open, throttle stick full down, choke, ignition on, flip until it pops. Then choke open, throttle full down, trim full open, ignition remained on, flip until it starts. Both needles at 1-1/2 open for reasonable starting points if you need to start over again with needle adjustments.
