RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   control horns - hole size? binding? (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/2789801-control-horns-hole-size-binding.html)
kregan 03-21-2005 05:20 PM
I am starting to mess with the Rocket city (or whatever) control
horns that come with the hardware kit. The kit has 6/32" button
head screws and lock nuts to be used as pins in the horns, but
the 1/8" holes in the rocket city horns are extremly tight on the
6/32" bolts.
A #29 drill bit seems to be a good choice for the holes, tight, but not
binding. Am I missing something here? I have never seen this
mentioned befor?
Another alternitive is to just run a 6/32 tap down the pin holes...
this may be a better solution since the 6/32" bolts have no shoulder
for the plastic to ride on.... the pivot point will be riding on threads as
it stands now?
rctom 03-21-2005 05:25 PM
RE: control horns - hole size? binding?
Yes, you are missing the instructions for the horns, or you didn't read them.
Send an email to [email protected] and I'll send them to you.
TF
flier 03-21-2005 06:19 PM
check . . .
kregan 03-21-2005 07:17 PM
Sorry, you are correct, I read that lat last night when i was pretty sleepy.
ORIGINAL: rctom
TF
