Edge 540t question
Hi guys !
I was wondering that there is a openning from the cowl to the tail..Like all others....should I put a ply sheet so the air wont come in the fuse when the motor will run ??! Or just leave it like this ?!?! thx Julien |
RE: Edge 540t question
Your choice! some close it some dont. I diden't
It won't matter either way.
TF |
Not that you fly like this but. I have seen a few pilots make mistakes on there final and if you field is like ours you have some tall grass out there. Well if you ever spend any time flying in the weeds you will wish you had covered that whole.
If you decide to cover any of the openings up, use Monokote or Ultracote. They are a lot lighter than wood and much easier to remove later.
Hot Tip!!!!!!!!
ORIGINAL: Silversurfer If you decide to cover any of the openings up, use Monokote or Ultracote. They are a lot lighter than wood and much easier to remove later. |
| All times are GMT -8. The time now is 11:19 PM. |
