RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   28% Edge engine range (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/3004185-28%25-edge-engine-range.html)
Mikel-t 05-23-2005 06:38 PM
I recenlty got a great deal from a club member on a WH Edge and want to know if I should install a NIB US 41 engine in it "AS-IS" or will I need more HP? Any thoughts about reworking the carb, etc. ? I was intending to stick the 41 in a much heavier TF P-51 GS kit I'm building but at the rate I'm going it'll be a r-US-t 41. THanks in advance
Mikel-T
For nasty stains always use Prop-Wash ! .................if you plan to "Fly by the seat of your pants!"
mstroh3961 05-23-2005 07:07 PM
RE: 28% Edge engine range
While it might fly it around in a circle, I think you wont be happy. stick with 50CC class, DA ZDZ Brisson ect....or Even the mvvs 58. Mine has the DA-50 and vertical is ballistic.
flier 05-23-2005 07:52 PM
Mikel-T ,
The US41 would be the weakest engine ever installed in this plane.
If your wanting to enjoy the performance the plane was designed for, you
should get a engine in the 1 to 1.5 HP/Lbs area.
Any light 50cc to 62cc engine will do the job well.
The plus of getting a 50cc over the 62cc is that many more planes are being
designed for this size engine now.
Most popular engines for the 28% Wild Hares;
1. DA 50
2. ZDZ 50
3. Brison 3.2
4. BME 50
5. FPE 3.2
6. Taurus 52
7. MVVS 58 (evo 58)
8. 3W 50
9. Zenoa G-62
At only 3HP & 4.5 lbs. the US 41 will be a big disappointment.
Hope this helps,
Mikel-t 05-24-2005 03:02 PM
Yeah, I thought so, ....now where the heck is my checkbook?. THanks for the push I needed.
Mikel-T
BlenderBender 05-24-2005 03:39 PM
My Brand new DA 50 came in today! Can't wait for my 300LX to get here now!
Tired Old Man 05-24-2005 08:43 PM
The lighter the engine, in the 50cc class that is, the better the performance. Even if you have to temper the weight by the price a heavier engine will still provide excellent performance.
I've seen the plane work with a Brison 3.2, a DA 50, a BME 50, and a G-62. None of the engines were a dissapointment, so go with what you can squeeze by the wife of significant other.
