Stand-off length
What is the proper stand-off length for a DA 50 mounted on a 300LX? Thanks, Jared
RE: Stand-off length
3.25
yep, what he said :)
Is the best way to get the 3.25 standoffs premade?
The cleanest way is to have them pre-made, my friend makes them for 25 bucks a set, but he won't be back from vacation for 10 days or so.
I personally used a 1/4 ply spacer as reccomended by Tom on my first Wild Hare, and it sincerley worked fine. On my replacement I used the pre-made, and love them, as well. personal preference. ORIGINAL: BlenderBender Is the best way to get the 3.25 standoffs premade? |
1 Attachment(s)
I took some 1/8" aluminium and cut it up to make up my missing 1/4"
:eek: i took my kids old skateboard
got a 1.5 inch hole saw cut out 4, drilled a hole in middle of each, perfect size. ta daaaa signed mr kind :eek: |
im running an edge 540t with da 50 and 3 inch standoffs
ORIGINAL: MrKindNuggz :eek: i took my kids old skateboard got a 1 inch hole saw cut out 4, drilled a hole in middle of each, perfect size. ta daaaa signed mr kind :eek: |
The 3 inch standoffs I got from DA were 1/4 inch too short, ergo the spacer needed. I'm curios how you got yours to fit.
The standoff's DA sent me were only 2.50.... I figure I will just order some 3.25" and be done with it.
Thanks Guys John |
I used the 2.50" standoffs and cut four 3/4" spacers and used longer
bolts. You can cut 1" x 1" squares from 3/4" plywood as spacers. ORIGINAL: BlenderBender The standoff's DA sent me were only 2.50.... I figure I will just order some 3.25" and be done with it. Thanks Guys John |
If you contact DA they will swap the 2.5" with the 3". Then you only need to make up 1/4"
Thanks Ken!
John |
| All times are GMT -8. The time now is 10:15 AM. |
