RCU Forums
-   WildHare R/C Support (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/)
-   -   shake -RATTLE- roll (https://www.rcuniverse.com/forum/wildhare-r-c-support-355/3502268-shake-rattle-roll.html)
buchtes 10-29-2005 05:59 PM
shake -RATTLE- roll
on my last four flights with the WH Edge ( 28%, Brison 3.2, Bisson Muffler), I noticed a rattle somewhere within the airframe and cannot locate it. All engine and flight components and mounts are tight, so seems the entine airframe up front, ie: firewall, bulkhead, gearmount ect.
Anyone else with some spooky noises they cant locate???
skyesdad 10-29-2005 07:44 PM
RE: shake -RATTLE- roll
check out the canopy one of the guy's i know had a rattle mystery noise and it was his canopy/hatch a little thin foam tape and done.:D
Cappy69 10-30-2005 12:43 AM
Yeah...had the same thing. I just hit the dowels with light coat of thick CA and activator...problem solved :). You also might want to check your wheel pants. Even with them tight, they vibrate a bit and cause a little rattle sound when flying....no big deal.
Cap
papadale 10-30-2005 05:45 PM
I had a similar problem with unexplained noise on my 260. I found out the servo leads from the elevators was drumming on the ultracote. I made some simple paper tubes to enclose the wires and it solved the problem.
Good luck
Dale
buchtes 10-30-2005 06:04 PM
avicrash & Cappy69
Bullseye, Canopy was the culprit, solved it temporarely with Teflon Tape over the dowels.
Thanks Guy's and Happy Landings
